Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
How to install the program in my flashdrive the original from u3
I formatted the flashdrive because of viruses and i lost the program
  • 31 Answers
Http://www.sandisk.com/DriverDownload/index.asp
Under product type, select "USB Flash Drive", operating system doesnt matter, and click Find Driver, on the next page, select U3 Software Installer, second from bottom. You will have to do a free registration I think, but its nothing major.
Good Luck!
Posted on Jan 25, 2009
Giving error information with different character almost like displaying another language
maybe it's viruses. try to clear your flashdrive from viruses. then format it, use only format program from you flash drive manufacture (DON'T USE WINDOWS UTILITIES)
Aug 17, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I want to remove all my program and setting to my laptop couse some one allways monitor my program. i want to change all setting and program.
What you want is called a system restore. Before you do anything BACK UP ALL OF YOUR DATA, as it will be wiped during the process.
Use your restore disks, or look on your D:\ drive.
I would like to mention that it is T-O-N-S easier to find and remove any monitor program....Also, you will need to reload all non original programs, and many times you may lack the key code to activate programs that you already own. WAAAAAAAY easier to extract what you do not want.
Doc
Jul 08, 2011 | Computers & Internet
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to unlock a u3 drive?
To unlock a u3 USB drive, you need to follow the following steps. Before proceeding be sure that you backup the thumbdrive just in case, and also don't have any programs using the flashdrive (including any instances of Windows Explorer).
  1. Run the launchpad program from the USB drive
  2. Double click on the icon to open up the main windows.
  3. Click on "settings" and the U3 Launchpad Settings.
  4. click on the uninstall tab on the side and then Uninstall U3 launchpad.
Feb 28, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My u3 flashdrive has lost all the u3 system files and the partiton with those files has come up with a title of 20050607 with no files. help
You need to format it to have your drive installed with a new files sytem. Format your drive using, Fat32 or Fat 16.
Dec 23, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
How to download softwares to my sandisk u3 flashdrive
As you may know your U3 Smart drive has a small OS that allows you to run Your applications on another computer. This OS shows as a CD-ROM icon on which you click to execute the LaunchPad (TheOS) of the Cruzer. In addition to that you have the icon of a regular drive. (Usually the Drive letters are consecutive G and H for exemple.) When you safely remove one both are unmounted at the same time.
Once the LaunchPad has been executed, it installs an icon on the sys-tray. When clicked, that tray icon opens a pop Up window, giving a menu of the applications installed and which you can run on the host computer, but from your drive (U3 Smart Programs on the left) and on the right various menu options
  1. to explore the drive,
  2. configure the drive(settings),
  3. add programs (to download additional U3 programs),
  4. and enable security. etc.
So if you want to download additional U3 Programs to run from you drive you use the Add programs (option 3 in the list above)
However, if you just want to put regular files on the drive (pictures, text documents, etc.) you do as you woul for nay drive: You drag and drop the files, not on the CD-ROM icon, but on the other drive. You can also use the Explore option (option 1 in the list above) to open the second drive to see what is in it, add files, remove files etc.
Hope it helps
Nov 10, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to convert my installed programs on my cruzer u3 flashdrive
hi funny,
first do a system back-up, (safe all the content of your disk plus installed programs an configuration using either the included windows back-up wizward(if you still use Win2000) or another freeware program,
then copy the resulting file onto your flashdrive(make sure it has sufficient space).Done.
Sep 29, 2009 | Electronics - Others
Too slow to run to PC
you need to: 1 backup any documents you want to save 2 download powermax (low level format utility) - http://digilander.libero.it/YorkOne/powermax/ - download and burn to cd >>> powermax-4.09.iso
3 have a copy of windows w/ valid serial key - also have discs for any other programs you will need to reinstall (ms office, virus protection, etc...) 4 dowload and run win driver expert ( backs up all your drivers) - http://www.softpedia.com/get/System/Back-Up-and-Recovery/WinDriver-Expert.shtml - save the backup of the drivers to a cd or flashdrive - i suggest you save the actual program to the flashdrive or cd as well AFTER you have done all that: insert the powermax cd into the laptop or cpu and boot it up. Run powermax (you are formatting the main drive) insert your windows cd and reboot cpu (install windows) reinstall your drivers reinstall your applications and virus software - remember DONT go online to do updates until you installed the virus scan software and updated the virus definitions ( u dont want to have to do this all over again because of a virus, lol)
Feb 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Cruzer program no longer on flash after viruses were removed
New ones avail:
  1. Microsoft and SanDisk team up on U3 replacement - Engadget Microsoft and SanDisk team up on U3 replacement .... is actually pretty good, but they charge you extra to be able to install any program not on their list. ...
    www.engadget.com/2007/05/11/microsoft-and-sandisk-team-up-on-u3-replacement/ - 99k - Cached - Similar pages
  2. GnU3zer U3 LaunchPad replacement (download torrent) - TPB Oct 28, 2006 ... GnU3zer U3 LaunchPad replacement ... The windows CD autorun function can execute ANY program specified in the autorun.inf file provided it ...
    thepiratebay.org/torrent/3547144/GnU3zer_U3_LaunchPad_replacement - 16k - Cached - Similar pages
  3. Microsoft, SanDisk to Replace U3 Drives Microsoft and SanDisk on Friday announced a technology-sharing agreement that will produce a replacement for SanDisk's U3 line of USB smart drives by the ...
    www.physorg.com/news98193946.html - 55k - Cached - Similar pages
  4. Microsoft and SanDisk still working on StartKey - the new U3 ... Mar 7, 2008 ... Microsoft and SanDisk still working on StartKey - the new U3 replacement ... Microsoft and SanDisk Expanding on and Replacing U3 Smart ...
    www.u3-info.com/sandisk/microsoft_and_sandisk_still_working_on_startkey_the_new_u3_replacement - 13k - Cached - Similar pages
Jan 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How can i recover my files from my usb flash drive?
It's possible that you are still suffering from the effects of the virus. You can try to download a (free) program called "Restoration" and run it. Here's the link:
http://www.download.com/Restoration/3000-2094_4-10322950.html
If you manage to recover your files, I would recommend that you re-format the flashdrive to make sure that you are getting rid of the virus, then re-install your flashdrive software if you use it.
Nov 18, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
113 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
