Question about Palm Zire 72 Handheld
AHHHH!!!! My Zire 72 handheld wont turn on. I pressed the power button, nothing. I pressed the buttons on the front, nothing. I pressed the reset button, nothing. I charged it for 3 hours and still nothing. I even plugged it into the computer and nothing. But when i plug it into the charger the green light turns on.... Help Me!! peace ~Megan
  • 1 more comment
  • Anonymous Nov 18, 2007
    i used my z72 to play mp3 then i slept, when i woke up my z72 is turned off, i thought it was just battery empty so it icharged it but i've been trying to turn it on still it wont work...
  • Anonymous Jun 24, 2008
    I have this same problem
    Plugged into the computer--green light comes on when plugged in-but NO power to turn on!
    This is all I can think to do? Any suggestions?
    What do I do? Please help!
    Thanks,
    Barbara
  • 633rose Mar 17, 2009
    I have just had exactly the same experience. The screen is off, even when plugged in for charging. It will not respond no matter where it is plugged in. Any and all help appreciated!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Posted on Jul 25, 2007
SOURCE:
I would like to give my Zire 31 to a friend but need to erase all my information from it. How do I do this?
Do a HARD RESET on your PALM ZIRE 31.
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Jun 28, 2011 | Palm Zire 31 Handheld
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
May 26, 2010 | Palm Zire 31 Handheld
I put a password on my palm and don't remember it. i want to unlock it.i tried resetting it but it don't work.
You may need to do a hard reset.
To perform a hard reset:
1. Press and hold the power button on the front panel of the handheld.
2. While holding the power button, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press and release the reset button.
3. Wait for the Palm Powered™ logo to appear; then release the power button.
4. When a message appears on the handheld screen, warning that you are about to erase all the data stored on your handheld, press any other button to perform a soft reset.
Mar 01, 2010 | Palm Zire 21 Handheld
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Nov 03, 2009 | Palm Zire 21 P80730US Handheld
How do I do a hard reset? I tried a soft reset with no luck. I have a fatal alert: memorymgr.c, line 3632, NULL handle
Hold power button while pressing reset button release release the power button when you see YES/NO confirmation to erase all data. Once you choose Yes, It will set everything to factory default. Personal data will be erased.
Jun 30, 2009 | Palm Zire 72 Handheld
Hotsync
do you want to completely delete all the data on your palm zire if so try a hard reset (deletes everything!)
To do a hard reset:
1.
2.
Wait for the Palm PoweredTM logo to appear; then release the power button.
3.
4.
Mar 16, 2009 | Palm Zire 21 Handheld
Palm zire z22 went dead
while pressing the up button on the front, press the reset button on the back. if the Palm screen comes up allow it to reset, then plug it in to charge. I found this instruction for a "soft reset" online.
Mar 12, 2009 | Palm Z22 Handheld
Palm frozen - Won't Move
o at the back of ur palm is a reset button just press it and it should be fixed
Sep 07, 2006 | Palm Zire 31 Handheld
Fatal exception error
hold down the up button and use a paper clip or tip of your stylis to reset, do both of these at the same time.
Aug 08, 2006 | Palm Zire 72 Handheld
Palm Zire 72 Handheld Logo
299 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
