Question about Yamaha HTR-5960 Receiver
No dolby digical in DVD mode.
All connections are checked. PCM is on and i know it has something to do with this. Sound in stereo, 7 channel or pro logic only. Help
  • leonardlavig Jan 26, 2009
    Thanks for the input. Ended problem by going into Blue Ray DVD player and checking to see if PCM was somehow turn on by someone else in the family (my ******* wife) that *****.
    Scholar:
  • 93 Answers
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Posted on Jan 25, 2009
All the speaker outlets seem to work fine, except the fronts, all will work, but if i plug the fronts in, all the sound then tends to just fade away, and then i have nothing, no sound. i can't figure...
I would:
1- First make sure you are properly testing using a reliable source, such as a CD Player or itunes. 2- Make sure the Listening Preset is not on Dolby Pro Logic. Make sure it is on Stereo mode and see if the problem persists.
What usually happens is that when listening to 2ch (Left and Right) Audio such as Television or Music and Dolby Pro Logic is on as a preset, Dolby Pro Logic analyzes both Stereo tracks, tries to detect the voices (center channel), ambient sounds (surround and fronts) and processes the signals into a 5.1 or 6.1 System. You tend to get a fading effect when Dolby Pro Logic is selected and listening to an old VHS, DVD or even music.
To remove a preset, make sure you select the Stereo button at the bottom left of the remote to pan through the options.
Hope this helps
Jul 21, 2011 | Harman Kardon AVR 230 6.1 Channels...
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
I have comcast basic cable. Recently I have six channels (always the same ones) that don't have sound. All the other channels are fine. We have a small tv in the bedroom also connected to the cable and...
Try changing the audio settings in your tv. Sometimes changing from pcm to dolby digital or vice versa can get your audio back up on these channels. Remember some stations are broadcasting in digital pcm and or dolby digital. I would leave tv on pcm. If that doesnt work check to make sure your not in a second audio mode (meaning set is on sap) sometimes a customer will accidentally hit the sap button. Put unit on stereo setting
Oct 22, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My receiver switched from dolby digital to pro logic, but I cannot seem to get it to switch back. It is connected through optical audio to a motorola qip7100 hd receiver. i know that the channels are...
Check the settings in the Motorola to make sure it's outputting Dolby Digital instead of PCM stereo.
Indicators on the receiver can tell you if you're receiving mutlichannel audio or not.
Aug 22, 2010 | Yamaha RX-V995 Receiver
Samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Jul 07, 2010 | Samsung HTC550 Theater System
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Yamaha RX-V663 wont play rear surround
The best way to get Dolby sound working is to connect the components using the optical links.
As long as you are using PCM the Dolby sounds will never get to your system. It's switching the Dolby sound off as soon as it detects PCM. I think the only way you will get Dolby on is via a optical cable which should let you have bitstream.
Mar 12, 2017 | Audio Players & Recorders
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Yamaha HTR-5960 Receiver Logo
245 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
