Question about Dual Xdm6351 Am/fm/cd/mp3/wma Car Audio Receiver With Usb & Aux
Dual xdm6351 display brightness
Dim display
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
Where is the fuse on an Where is the fuse located on a Dual Electronics Corporation XDM6351 and how do you change it?
The fuse is on the yellow wire of the connection loom, external to the unit. It is an inline 10 amp AGC fuse.
Jul 03, 2014 | Dual Electronics xdm6351 Am/fm/cd Mp3 Usb...
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
I cant go through windows display, because the lcd monitor is already block out, but the lcd monitor is still functioning,, its total dimmed.? can you help me?
on my toshiba, there dual function F-keys. on mine a little 'sun-looking' brightness icon is on F6 (brightness down) and F7 (brightness up). at the bottom left is a key labeled 'Fn'. you need to hold this down while tapping whichever F-key on your Acer is labeled with the 'brightness up' symbol. try it- it may work!
good luck!
Oct 05, 2009 | Acer Aspire 4720 Notebook
I no longer get a bright display. The display stays on dim even when I switch to bright. I cannot see the screen at all during the day. I have a Cobra XRS 9930 that has developed a very dim display....
I had the same problem. I also live in Florida and I guess the display overheated in my hot car after time. I eventually bought a new one but it did the same thing.
May 18, 2008 | Vehicle Parts & Accessories
Brightness Question
There is a way of dimming the display and it is by holding the power button for more than 3 seconds. After 3 seconds the display will lit up or dim depending on how it was before.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Dual Xdm6351 Am/fm/cd/mp3/wma Car Audio Receiver With Usb & Aux Logo
66 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Lawrence Oravetz
Rishan Ranatunga
Level 1 Expert
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
