Question about Lennox Heating & Cooling
Lennox 8 series ms8-z0-2ap3a error code H1
Error code h1
  • 142 Answers
SOURCE: Amana PTAC ptc093d35ar, when i
H1=High voltage protection engaged. Power supply voltage is too high. Check for incoming power at correct voltage.
Posted on Feb 10, 2009
SOURCE: password for alfatel H1
the password for alfatel H1 is 1122
Posted on Mar 10, 2009
SOURCE: Alfatel H1 Mobile - Music Sparkling Light
To switch of the light goto setting -->> phone setup --> set run light off.
Posted on Jun 02, 2009
RixsFixes
  • 2200 Answers
SOURCE: Reseting Sony H1 digital camera
Hi
If you examine the body of the camera there is a tiny reset - which is recessed into the body. To access it you need somthing such as a bent out paper clip wire.
Hope this helps. Remember to rate my answer. Thanks.
Posted on Jul 16, 2009
SOURCE: Format code of alfatel h1
put Password 1122
Posted on Aug 28, 2009
Have error code H1 on my freezer. I have it set on 5 what does it need to be
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Jul 05, 2017 | Refrigerators
What the code h1 means samsung washing machine
H1 on a samsung washer is a heating problem.
You need to check the heater and the control unit and find the fault form there.
If you have a multimeter you can test the heater as it should read about 28 ohms. If faulty then the heater will need to be replaced to cure this.
Check it out and see what you find but the H1 error code is a heating problem.
~~~via just answers
Feb 14, 2016 | Samsung Washing Machines
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Side by side fridgidare wont stop beeping and showing H1, freezer door was cracked all night and our ac was out, tried to unplug and reset still nothing???
Hey Nikkie, I appreciate your post!
I see that your Frigidaire refrigerator is beeping and displaying the error code of "H1". An "H1" error code means that this is a high temperature within the refrigerator. Since the door was left open all night the refrigerator is registering there is a high temperature. I would suggest keeping the door closed and allowing the refrigerator to get back to the correct temperature. This may take anywhere from 24 to 36 hours for the temperature to stabilize. Hopefully this information is helpful to you. -Matt
Dec 25, 2015 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
What to do when h1 is flashed in ifb automatic front load washing machine
Cannot find anything about H1, but error code E01 is door not closed properly. An instrument at work sometimes reads "h1" and this indicates a "high" reading, but don't know if that is really relevant here. Sorry I can't help any further. Good luck.
May 19, 2015 | IFB Washing Machines
WHAT FFHS2322MS H1?
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is providing a "H1" error code. However, "H1" is an invalid code. I show a code for "HI" and that stands for high temperature in the freezer compartment. If you are receiving this error code but your temperature is cold inside your freezer it could be a miscommunication within the board and I would perform a reset on your appliance by flipping the household circuit breaker for ten minutes. I hope this helps. -Matt
Aug 18, 2014 | Frigidaire FFHS2322MS
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
Oct 13, 2012 | Frigidaire FSC23F7DSB Stainless Steel Side...
Samsung washing machine error h1
hi !
look here : http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes.html
Aug 13, 2012 | Washing Machines
Heating & Cooling Logo
558 people viewed this question
Top Lennox Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Lennox Heating and Cooling Expert? Answer questions, earn points and help others
