Question about TOA Electronics A912MK2 Amplifier
Change fuse on a-912mk2 amp - TOA Electronics A912MK2 Amplifier
Toyota hilux 2000 3ltr glow fuse 80A how do i change them out
Let me know if this is helpful:
Replace 100A Auto Fuse
also You need to remove the fuse panel from the fender well & take out the bolt that HOLD THE FUSE FROM THE BOTOM. I did the same thing to mine first time and ended up paying $50 from the dealer for a new one~
removing 80 amp fuse
Jul 23, 2016 | Toyota Cars & Trucks
Why does fuse 15 keep blowing on citroen picasso 2007
change the fuse from 15 amp to 20 amp will cure your problem
Jun 06, 2014 | 2007 Citroen Xsara Kombi
Wire from car battery to amp melts fuse holder
total the fuses on the amp eg.3 -20amp fuses = 60 amps and get a fuse holder that can handle that amount of amps the amplifier draws with matching fuse and change the one that was melted ,also very important is to have a clean grounded wire to chasis from amplifier.
Mar 10, 2013 | Maystar QXV10 Car Subwoofer
My toa a-912mk2 amp does not work and the red protect light stays on
• Check for shorted power transistors, and extract in pairs.
If it powers up, without protect..
• Check again for possible additional components before replacing
the bad ones.
A good amp never produce an over of 0.7V on its output.
Sep 06, 2012 | TOA Electronics A912MK2 Amplifier
Where to buy the 80amp fuse for chevrolet malibu
You only change a fuse if the system has a problem &
the fuse blows out
They don't go bad & need changing
Jun 17, 2012 | 2005 Chevrolet Malibu
Which fuse do I need to change for electric seats and door locks in my 2003 mercury mountaineer
i have bad news for you the seats and door looks do not chair a common fuse.
power door locks, 4 fues in this system
in the under hood fuse box fuse # 16 15amp, fuse # 2 30 amp, fuse # 22 20 amp
in side fuse box behing left side of the dash fuse # 20 5 amp.
power seats
in side fuse box behind left side of dash fuse #1 30 amp, fuse # 2 30 amp.
Jul 29, 2011 | Mercury Mountaineer Cars & Trucks
Hello i just bought a power acoustik cpt1-4000d amplifier and we and a friend of mine were hooking it up and he accidently blew the 4 30 amp fuses in the amp. so we replaced them with 4 40 amp fuses and...
You shouldn't have replaced 30 amp fuses with 40 amp fuses. The 30 amp fuses were in there for a reason. You'll probably find that if you put the correct sized fuses in then it will work. If it doesn't then you have burnt out or melted something and it will need repairing.
Nov 11, 2010 | Car Audio & Video
How do you wire from the mixing board to an old school L-41 module that has 3 screws, for my toa 912mk2 amp?
The L-41...3 screws?...Is that a LOW-Z input?
Check the TOA site.
They have all the manuals for download
Rate my help if you could and get back to me
Thanks
Aug 29, 2009 | TOA Electronics M-900MK2 Amplifier
Sony xplod xm 200gtr
Either You Fired Your Amp Or Wires, If You Got The Money Replace The Wires, Also Trying Grounded Your Ground Wire To Something Else.
Jun 09, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
TOA Electronics A912MK2 Amplifier Logo
76 people viewed this question
Top TOA Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a TOA Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
