Question about Whirlpool WTW6600SW Top Load
Where does part p/n8565188 rev a go
Where to install this sensor on this motor
After hour or two car will miss, almost felt like a fuel/air issue. Then acts like transmissions gone. As I accelerate it revs and shifts. (transmission guy said its a newer tranny, not the problem).
there is a few cars that will rev like this that is the auto choke to some engines coming into play (mostly noted on a dodge 1500 v6 mag year model 2000) this is sometimes normal as the auto choke will rev the motor for a while or so before letting the motor calm down per-say as the motor is warming up
Apr 22, 2017 | Cars & Trucks
Motor revs on cold idle how can it be fixed
run the fault codes to find the problem sensor
most likely an ambient temp sensor that is reading the air temp incorrectly
Aug 19, 2016 | Cars & Trucks
Revs go up down idle
Have the throttle positioning sensor checked.A faulty sensor will cause the car to run poorly.
Mar 28, 2014 | Ford Contour Cars & Trucks
My 1997 chevy s10 2 wheel drive will crank but won't rev up.
motors do not rev up because they are not getting correct air/fuel for the throttle opening. So check that the accelerator position sensor is working and if you have a cable operated throttle to the body check that it is not broken. IT may be your throttle motor is not working
Mar 19, 2014 | 1997 Chevrolet S-10 Pickup
Saturn vue 2008 motor won't rev up and vehicle barely moves
possibly a bad Throttle motor or Throttle position sensor most newer cars do not have Cable operated throttles and are run by a sesnor in the foot pedal and a motor in the throttle body.
Feb 15, 2013 | 2008 Saturn Vue Red
2000 pontiac grand am 3.4 motor auto trans 4 door.Car starts and drives okay motor seems to stumble slightly between 3000-4000 rpms. with car stopped in park try to rev motor will only go between 3200-4000...
Hi Tom your vehicle is equipped with a Rev limiter it will not allow you to rev the engine above 4000 with the trans in park; as for the first problem you may have one of two things, one of the spark plugs or spark plug wires is bad or you have a flat spot on the throttle positioning sensor in which case have be replaced. Good luck?
Mar 10, 2011 | 2001 Pontiac Grand Am SE
I have a 1994 Honda Accord and it will not rev over 3500 rpm, it also has a check engine light on, I tested it and it says the crankshaft sensor it gone, so I replaced the distributor (crank sensor is...
i know these post may be old but i found the solution to rev problem, i have a 94 accord ex was revin' at abbout 3200rpm, so i ran a diagnostic and found it to be the crank sensor(code 4). not what you may or may not know this sensor is part of the distributor. so you can do one of two things go to a salvage yard and try to lacate one ($100) or buy it new ($400). after install reset the ecm and let it recalibrate and you ready to roll.
Feb 07, 2011 | 1994 Honda Accord
My 2000 max also revs up on its own.
Throttle position sensor or mass airflow sensor needs to be checked.
Jul 11, 2009 | 2000 Nissan Maxima
Accellerating
What fuse did they change? Are you sure it wasn't a relay or sensor they changed? You need to check the computer codes and test the fuel pressure. It wouldn't be a clogged catalytic converter if it happens only occasionally but could be a bad O2 sensor, fuel pump or filter, fuel pressure regulator, VSS (vehicle speed sensor), dirty throttle body or bad IAC motor, throttle position sensor, MAF sensor. See there's lots of things to check that's why you need to check the codes and fuel pressure first.
Apr 16, 2009 | 1992 Volkswagen Passat
1998 Pontiac Grand AM GT motor revs
it would not be an O2 sensor, period, they would never cause a high idle, have u had this checked for trouble codes? A sticking idle speed control air bypass can cause this problem as well as a throttle position sensor, but run the codes, Kragen does it for free was well as other parts stores.
Mar 10, 2009 | 1998 Pontiac Grand Am
Whirlpool WTW6600SW Top Load Logo
Dan Webster
Dan Webster
Sal DeAngelo
