Question about Aiwa Audio Players & Recorders
Replacing the belt on goodmans mini turntable GSP400P
The beltcame loose whilst playing a record recently and i have no idea how to fix it. can anybody help?
techman
  • 3130 Answers
SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Posted on Jun 15, 2007
informatica
  • 1114 Answers
SOURCE: Belt Drive
The belt is replaced as in the following diagram from the manual that you can download on the link below: http://www.lpgear.com/at_pl50_om.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 27, 2007
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
  • 396 Answers
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Posted on Jul 21, 2010
How do I fix a turntable used for playing records from being slightly slow
Try replacing the drive belt. Look under the platter for a 'rubber band' that would connect the platter to a drive motor. I bet it's loose. My other idea is crazy, however, they do sell an item called a "variac" which has a knob to control the voltage to the player. It's big and bulky and not worth the trouble. I'm a musician so I have to have a player up to speed or slightly detune my guitar. Good luck..
Jan 13, 2015 | Audio Players & Recorders
Crosley cr249
are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
Jun 19, 2008 | Crosley 0187SST Turntable
I have an old record player. It was made in the 80's according to my mom. I have recently started to use it( it hasn't been used since 86). With the exception of 45s, the record player will only play side...
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
Aug 24, 2014 | Audio Players & Recorders
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
Mar 24, 2014 | Technics SL-BD20D Turntable
Playing records too slowly
It's likely that the belt has moved off where it should be. If the stylus was damage it would slide across the record or cause poor sound. It would not affect the speed unless there was too much pressure on the stylus, but you would feel that as the head of the arm would feel heavy.
May 24, 2013 | Crosley Conductor CR73 Turntable
Turntable doesn't play
If the turntable stopped spinning then then the turntable belt maybe broken or has slipped off the drive.
Mar 02, 2013 | Emerson Nr303tt Mini-Stereos
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
Sony ps-lx250h belt-driven turntable runs too fast.
Is there an adjustment knob? if so use that! if not it will have to be adjusted from under the turntable!
this should fix ya!
Dec 12, 2008 | Sony PS-LX250 Turntable
20 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
