Distorted one channel of sakura 737 power amplifier
Distorted left channel
2 Suggested Answers
  • 54 Answers
SOURCE: hafler dh220 power amplifier left channel distorsion
Sounds like your Power FET's are gone. Take it to a shop that specializes in high end or vintage gear. ....good luck...Rob
Posted on Mar 03, 2008
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
Quad 33 chanel bad sound when playing music
As you know that the right is good you can compare that with the left. First look around for burnt resistors or damaged parts.
The next thing to do is with an insulated tool poke the two channels to see what buzz sound each channel makes. You should quickly find the distortion section with this method.
Mar 07, 2014 | Quad Audio Players & Recorders
My 787 receiver is 10 years old. It worked excellent all these years . It developed distorted sound in the front left channel. I swapped speakers and confirmed that the problem is with the receiver front...
The problem will be in the power amp for the the left channel. One you have identified this on the circuit board you can compare the channel with the right. As they are both the same. Start with a visual check. If anything looks odd compared with the the right replace it. Distortions are often caused by a burned resistor. Though the main power transistors or IC can cause it too. If you can't find anything visual I would replace the main output device(s) for the left channel.
Nov 21, 2017 | Audio Players & Recorders
Bose acoustimass 3 left channel fuzzy
Being Bose, the service department will require the unit back for service.
Jun 14, 2017 | Bose Audio Players & Recorders
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
Left and right channel distorted denon pma510
Anything that distorts both channels has to be something where both channels go in and out of it. Is the main amp an IC Power Amp such as the one shown below. If it is replace it.
Mar 25, 2013 | Audio Players & Recorders
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
Sound from left channel is small and distorted.
The distortion might be caused by a resistor. The loss of volume could be the capacitors, but you could try injecting signals into the transistors to see if any has gone. They can cause the distortion and loss of signal. If you apply a soldering iron to any part it will heat up quicker, or you could also use a hairdryer for the whole thing. You can also get a freeze spray that cools things that have heat sensitive faults (available from electronic parts shops).
Apr 24, 2009 | Marantz PM-15S1 2-Channel Amplifier
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
54 people viewed this question
 Grubhead
Grubhead
