Question about Motorola CP185 (16 Channels) Two Way Radio
CP185 has intermittent static, when pressing button to talk screen displays "channel busy" and battery will not keep a charge.
  • Motorola Master
  • 1,654 Answers
Could be one of several issues. A few which come to mind are:
1) You have a bad or poorly charged battery. Static is a sign of a bad or poorly charged battery. Try swapping a battery from another radio, with a known good battery and see if the problem is solve. If this resolves the issue check your battery and charger. Tip: Clean all charge contacts with a pencil eraser to ensure good charging. Also, check your 3- or 4-digit date code on the battery. If more than 2 years old, replace the battery. (4-digit date code example 1303 would be 2013 the 3rd week; on 3-digit date codes the first number is the year and the next two the week of the year.)
2) You are trying to use the radio in an area where you are experiences high RF on your frequency. This is the "busy"... someone/something is on or near your radio's frequency and interfering with transmission. Try your radio at a different location and see if the problem persists.
3) Another radio in the workgroup is stuck in transmit, causing static, and the channel busy. Turn off other radios, one at a time, and see if the problem still exists.
4) Or if you have an audio device plugged into the radio, try unplugging it and see if the problem stops. FYI: All audio devices must be plugged or unplugged with the radio shut off. If you plug one in with the radio turned on, you can experience some unexpected intermittent issues.
If none of these seem to be the problem, your radio is likely in need of repair.
Best regards.
Posted on Jan 19, 2013
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Posted on Jul 30, 2008
SOURCE: Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Posted on Dec 31, 2008
eradiostore
  • 1654 Answers
SOURCE: Radio cuts out (screen goes blank) when you press "talk" button
You are correct, the battery is bad. When batteries begin to fail, they may appear to hold a full charge, but when put under a load they fail to maintain the proper power to fully power the radio. Generally you will notice screens going blank, poor or no transmit, etc. Simple solution, replace the battery. New batteries are available for around $30 (US dollars).
Posted on Mar 17, 2009
Radio keeps beeping when I turn it on? I confirmed its not because of a low battery but something else.
A few thoughts:
If it is a long continuous beep this can be an indication of having the channel select set to a channel which is not programmed.
If it is a beep that only occurs when you press the PTT button, similar to the low battery beep, it could be a battery, battery contact, or internal battery contact issue. Clean battery contacts between radio and battery, as well as external contacts, with a pencil eraser to assure a good connection.
If it is a beep that occurs periodically when pressing the PTT button, it is possible your radio is programmed with busy-channel-lock-out (talk prohibit tone), which would not allow you to transmit on a frequency which is already in use.
Best regards.
Oct 11, 2013 | Motorola Mag One BPR40 Two Way Radio
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
CP185 radio won't stop beeping and is flashing red
Could be a variety of problems. Common issues might include a bad or poorly charged battery, an unprogrammed channel is selected, or you are programmed for busy channel lock out, and their is local traffic on your frequency causing you to be blocked out.
To test your battery, try trading with another radio which has a known good battery.
Check with your local dealer or a repair facility for more help.
Best regards.
Sep 23, 2011 | Motorola CP185 (16 Channels) Two Way Radio
My Sanyo AVM-3651g 36" TV keeps showing the
On the remote that came with your TV, press the Display button, which is directly below the Volume Up button. Pressing it once displays the channel number and time, pressing it twice displays the channel number continuously, you must have accidently pressed the Display button twice. Just press it once more to remove the display.
Sep 02, 2011 | Sanyo Televison & Video
Screen goes black. Put it in sleep mode. Then hit the start and it comes back on even with powercord in..what can fix it?
this could be probably due to static charges or corrupt bios settings.
Turn off the PC, disconnect the AC Adapter and remove the battery. Now press and hold the power button for 45 seconds.
Now download and install the latest BIOS update available for your notebook from manufacturer's website. If issue persists, reinstall the display drivers.
I hope this will help to resolve the issue.
May 20, 2010 | HP Compaq Business nc8000 Notebook
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
Motorola TLKR T3 communication problem
svp dite moi comment les refaire marcher car il y en a un qui recoit tout et l'autre rien du tou svp aider moi
Oct 04, 2009 | Motorola Talkabout T5720 (7 Channels)...
Mar 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Motorola CP185 (16 Channels) Two Way Radio Logo
148 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
