Question about PfaFF Sewing Machines
Pfaff varimatic 609 - PfaFF Sewing Machines
4 Suggested Answers
  • 517 Answers
SOURCE: pressor foot will not completely
Good day to you!!!
I am suggesting you to put an oil to that pressor foot and also all parts which you think need to be oiled so that it become soft and easy to use..
If this suggestion does not help please have a comment so that we can make another steps/solution to it...
Thank you and please do not forget to testify and rate me when it helps you...
Good luck...
Posted on Jul 15, 2011
SOURCE: How do you thread a Pfaff Varimatic 6091 sewing
sewusa.com has free threading diagrams
Posted on Aug 29, 2011
SOURCE: how to thread a pfaff varimatic 6085
sewusa.com has some threading diagrams
try youtube & ehow for video's on threading the machine
try pfaff customer service for a manual
sewingpartsonline.com
sew4less.com
sewingmanuals.com
Posted on Apr 16, 2012
Hi, I have a Pfaff Varimatic 6091. I sewed some 'too thick' fabric, and it has 'broken' my top tension unit. i.e. I can no longer set it at all, and when sewing the thread is all loopy.
If the upper tension unit is in fact broken, you will need to take it for service or find a replacement part.
This may be a shot--remove the upper thread, ALWAYS RAISE the presser foot, rethread from the beginning. Re-try your machine.
Apr 22, 2017 | PfaFF Sewing Machines
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
Apr 07, 2017 | PfaFF Sewing Machines
Pfaff varimatic 6091 What type of walking foot can i purchase for this model and are they very expensive ?
You could probably get away with a generic walking foot. They are available in the fabric store for a little under $20. Once you use one, you will wonder how you got by without it before!! I've attached a sample of a product that would work for you. Just be sure to NOT get the "slant" walking foot. That is for the Singer machine, and they have a different setup. Enjoy!!
Amazon com Distinctive Even Feed Walking Sewing Machine Presser Foot...
Mar 10, 2014 | Sewing Machines
How to thread a pfaff varimatic 6085
sew4less.com
sewingmanuals.com
Apr 15, 2012 | PfaFF Sewing Machines
Pfaff Varimatic 6085 purchased June 2001. Second time this has happened and it cost $60 to repair. When the needle is centered it hits the case holding the bobbin. If I move the needle to the right it...
Many users also had the similar bobbin locking problems. I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Aug 17, 2010 | PfaFF Creative 7570
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
PFAFF Varimatic 6085
did you get any feedback on this machine's problem?
i'm getting the same model by the end of the week.
thank you. chuck
Dec 22, 2007 | PfaFF Creative 7570
Sewing Machines Logo
65 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
