Distorted one channel of sakura 737 power amplifier
2 Suggested Answers
SOURCE: Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Posted on Dec 31, 2008
Distortion appears while trurnning up the volume on right channell
You just need to replace your volume knob for a better one , a couple of bucks 10 dollar
Jun 18, 2014 | Denon PMA-100M Amplifier
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
Left and right channel distorted denon pma510
Anything that distorts both channels has to be something where both channels go in and out of it. Is the main amp an IC Power Amp such as the one shown below. If it is replace it.
Mar 25, 2013 | Audio Players & Recorders
I have a Sherwood amp AX4050R which has distortion only on one channel. What could be the most likely problem. Where can I get a circuit diagram or service manual?
You don't really need one. Stereo amps are just mono amps times two with a single power supply. So if the distortion is one channel you still have the good channel as a guide to what is happening in the bad. It won't be the power supply, so just compare the two channels, you will find what is wrong that way.
Sep 03, 2011 | Audio Players & Recorders
Right channel is having distortion even if the voulme is turned off. I tried swapping the speakers and cables but still the distortion can be heard from the speaker. It is still coming even if the jumper...
you need to check for the filter capacitor on that channel, and going to the power amplifier. some distortion come from leak parts and need to trace that manually.
Apr 13, 2010 | NAD C325BEE Amplifier
Will a sony 600watt amp run a 10 300watt 4 ohm sub?
Yes, but the wattage numbers are pure marketing and have no bearing in reality or fact. In general, given realistic amplifier power specifications, a higher-powered amp will be a better and safer power source for any given speaker than an under-powered amp since the latter will probably have to go into severe distortion to produce the same loudness a high-powered amp can provide cleanly. Distortion kills speakers.
Jan 17, 2010 | Sony Class AB 600W Bridgeable 4-Channel...
The left channel is lower than right, i have checked all terminals etc..
Providing the effect is there on all inputs, plus there's no distortion, the problem could be caused by an Electrolytic bypass or coupling Capacitor in the pre-amp stage or higher.
If there's distortion, the problem is in the main power amp, with the 'things' on the heat sink.
Nov 01, 2009 | NAD C350 2-Channel Amplifier
Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
Distortion in a Yamaha CA-800
The only thing I can suggest is you look at parts that are common to both channels in the main amp part. Perhaps an IC?
Jun 13, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Distortion in one channel
your right output component (transistor or integrated circuit needs to be replaced)
Nov 11, 2007 | Alesis RA-150 Amplifier
56 people viewed this question
 Grubhead
Grubhead
