Question about Panasonic DMR-EH50 DVD Recorder
Timer programme setting was unsuccessful - Panasonic DMR-EH50 DVD Recorder
How do you cancel the sunrise sunset program and just use your own times?
Most dawn-dusk wall timers have programmable option... except aube/honeywell.
Most plug-in timers have various options... but some are just astronomic and not programmable
Following link will help identify timer so you can download possible manual with instructions.
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
Mar 17, 2015 | Hardware & Accessories
I have Titan Apollo 8 dual light timer I can't get
Not sure if you have the analog or programmable apollo timer.
Copy each link below, for analog and programmable:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Add a comment and describe timer in detail.
Gene
Jul 22, 2013 | Hardware & Accessories
Uhow do you program a 24 hour timer? Lost the instructions.
Timer is not identified.
1) Open following link for setting analog timer by experimenting with features:
2) If you have analog box timer, the following link might be helpful
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
3) Most programmable timers are 7-day. But some are 24-hour like Intermatic ET100 box timer, etc.
If you have programmable timer, then add a comment and describe timer in detail
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Hardware & Accessories
Friend left RCT100 timer programmed, it comes on the time programmed, but it goes off much earlier than it is supposed to. How can I correct this?
Most digital timer problems can be solved by resetting timer.
Open following link for possible instruction manual with troubleshoot steps
http://waterheatertimer.org/UPM-timers-and-manuals.html#Garrison
Check the following:
Program disable feature is not enabled.
Check 2 different sets of batteries: 1 set AA for transmitter, and 1 set button-cell batteries on back of timer
Choose between 4 different functions: programmable, photocell, countdown, or random
Using programmable mode: make sure there are no programming conflicts
Jul 20, 2011 | UPM Remote Control Timer Set
Can not properly set the required humidity level at 40%
You posted under UPM programmable wall timers.
These timers are not set for humidity.
Add a comment with exact product you are working with.
Feb 15, 2011 | UPM Programmable Wall Switch Timer
How do we set the time to stop on a UPM ETW350? I know how to set the time to start but i do not know how to set the time to stop. Thank you
In wall timers and manuals are shown on following link.
http://waterheatertimer.org/Programmable.html#ETW
ETW350 manual:
http://waterheatertimer.org/UPM-etw350.pdf
Select from 3 different functions:
1) 24-hour Programmable
2) Countdown timer function so lights turn off after period of time
3) Random function so lights turn on randomly and house looks lived-in
I am not going to write out the steps because they show in the manual.
But a specific part of the manual might be confusing.
So add a comment and I will help until we will get the timer working.
Nov 20, 2010 | UPM Programmable Wall Switch Timer
I need the instructions for a UPM Model 100 indoor programmable timer...
UPM100?
Do you mean UPM RTC100 remote control timer set?
Smarthome usually posts manuals with their products:
See if this is your product:
http://www.smarthome.com/2046/Programmable-Receptacle-Timer/p.aspx
pdf manual
http://www.smarthome.com/manuals/2046.pdf
add a comment if this is not your timer
Nov 20, 2010 | UPM Indoor Electronic Programmable Plug-In...
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Panasonic DMR-EH50 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
