Question about Toro Lawn Mower With Toro Power Tools
Snow blower spark plug replacement
I have a Toro S200 paddle snow blower that I don't have a user's manual for. I was wondering how often I should check or even replace the spark plug ?
  • 548 Answers
I would check it at the start of every season and clean it. If you note that it seems to be running rich and might have fouled the plug, you can always pull it and check it again. Probably not a bad idea to check it before you put it away for the season. As for replacement, it depends on condition. I would think that you should get two or three season's use out of it before needing to replace it, at least.
Posted on Jan 25, 2009
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Snow blower wont start
clean the fuel out and the carb , make sure you are getting spark close the choke to start then shut if off or it will foul the plug
Feb 17, 2014 | Toro Snow Blowers. Power Clear 18 in....
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
My toro s620 will not start I replaced the spark plug still nothing won't even say anything
Well, There is nothing like a good repair shop to take care of a problem. I would recommend looking at the diagrams at a site like www.arcolawn.com and consider the carburetor rebuild kit fuel line and the primer. Inspect the parts on the machine and order replacments right at the web site.
Good luck
please vote my fix up if you find it helpful
Joe
Feb 03, 2011 | Toro Snow Blower Scraper For S200 s620 New...
Snowblower will turn over but will not start.
check to see if its getting fuel if it is then change the spark plug if it still doesnt start then a carb kit is needed
Jan 18, 2011 | Toro Snow Blower Scraper For S200 s620 New...
I have a Toro S620 snow blower, I push the primer bulb and it starts right up then dies. If I keep pushing the primer bulb continualy it will keep running but the moment I quit it dies.
The carburetor bowl needs to be taken off and most likely the float and needle need replacing. When you prime the carb, this is shooting gas straight to the carb instead of traveling though the jets. This is a very easy task, but I know if you're using a snow blower you need it quick. The kit is about $5 and be sure to take your machines info with you.
Dec 30, 2010 | Toro Snow Blower Scraper For S200 s620 New...
Will not start no spark
No spark, lets start with the easiest, sure the plug is good? Not wet? With a clean dry plug still no spark, disconnect the kill switch, eigther at the ignition unit or at the switch itself (on the handle). If still no spark the ignition unit is bad. These are solid state they work or they don't. Hope this helps.
Dec 08, 2010 | Toro Snow Blower Scraper For S200 s620 New...
Toro 3650 snow blower paddles
I used a needle nose plyers to hold the nut. It still is dicey and a PITA-will let the dealer do it next time
Feb 28, 2010 | Garden
Toro S200 doesn't blow to the side as far as it did
It's possible your auger may be worn, and it is not moving / propelling enough snow to make up the difference to blow the snow at the angled setting. It may throw the snow forward better due to less resistance, rather than the snow having to propel around an angle / curve. Just a thought for now.
Jan 20, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Toro Lawn Mower With Toro Power Tools Logo
344 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
