Question about Rival Snow Cone Maker
Need to put the lid on it wont work for me
Just re'd item and no instruction included
Need ice cream maker storage lid
I think the timer might be the problem the trouble is I live in tenerife
Jan 15, 2014 | Bravetti KP160HFS 1 Quart Ice Cream Maker
Hi I bought this item off Ebay from a seller but they didn't send the instruction book. Any tips or idea's on how i work and maintenance on this item please any help would be nice.
The Instruction and Recipe book for the ICE-21 can be found here:
http://www.cuisinart.ca/pdf/ibs/en/ICE-21C_en.pdf
This is the closest I have been able to find to the ICE-20. Hopfully the models are similar and this will be of assistance. If not please reply or repost.
Thank you for using FixYa!
Aug 14, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Replacement lids for Salton Jars
I don't know the exact size you need, but for that kind of thing I go to Uline. They seem to have almost everything that no one else does. Their minimum order may be more than you want, though. http://www.uline.com/
Jun 11, 2009 | Salton Ice Cream Makers
Breville scoop factory ICM10 instruction
Hi, I have been able to solve this problem. I found the phone number for a Breville distributor, and called them. They were more than happy to send me a manual. They are H.W.I New Zealand ph 09 271 3980 . I hope this number will help others needing Breville manuals. you just need to be able to give make and model numbers.
Dec 09, 2008 | Ice Cream Makers
Need Proctor Silex Ice Cream Maker Manual and Container Lid
I have a lid for the older proctor silex. Contact me if you still need one. My canister rusted out so I can't use it anymore.
Nov 23, 2008 | Ice Cream Makers
Deni Ice Cream Maker Manual
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Freezer bowl not frozen!
Preparing the Freezer Bowl:
The freezer bowl must be completely frozen before you begin your recipe. The length of time needed to reach the frozen state depends on how cold your freezer is – for best results, place the bowl to the rear of your freezer where it is coldest. In general, freezing time is between 6 hours and 22 hours. To determine whether the bowl is completely frozen, shake it. If you do not hear liquid moving, the cooling liquid is frozen. For the most convenience, leave your freezer bowl in the freezer at all times so you can take it out any time for immediate use.
Features and Benefits:
  • Freezer Bowl – The double insulated freezer bowl contains a cooling liquid between the bowl walls to create fast and even freezing. In general, the required freezing time of the bowl is 6 to 22 hours before use. Additional freezer bowls are available separately for making double batches or different flavors without interruption. For additional information on preparing the freezer bowl for use, please see below.
  • Base and Motor Unit – The base contains a heavy-duty motor that is strong enough to handle everything from thick, rich ice creams to smooth frozen yogurts to slushy frozen drinks . The base unit features a generously sized on/off switch, rubber feet to prevent slipping and keep the unit stationary while in use as well as cord storage to keep counters neat and safe when the unit is not is use.
  • Lid with Ingredient Spout – The easy-lock, transparent lid secures to the base with a simple turn, allowing you to watch the freezing process as it progresses. An ingredient spout at the top of the lid is generously sized for pouring in ingredients and ideal for adding nuts, fresh fruit, candy pieces and more without interruption the freezing cycle.
  • Mixing Arm – The mixing arm mixes and aerates your frozen desserts and drinks, incorporating and blending all ingredients thoroughly.
  • Instruction/Recipe Book - The included instruction and recipe booklet helps you get started with over 30 recipes and variations for ice creams, sherbets, sorbets, frozen yogurts and frozen drinks.
  • Feb 29, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
    How to use it
    Try putting the plastic thing in the other way around, ,and yes the bowl needs to be frozen before you use...
    I'm in the same situation as you - not sure how to use, but have been told this much...
    Sep 13, 2007 | Deni 5150 / 5151 / 5152 / 5153 Scoop...
    Rival Snow Cone Maker Logo
    41 people viewed this question
    Top Rival Ice Cream Makers Experts
    Henry  Thomas
    Henry Thomas
    Dan Webster
    Dan Webster
    Stan Skaggs
    Stan Skaggs
    Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
