Question about VeriFone Vx 570 Countertop Solution Hard Drive
No *ZTCP Variable - VeriFone Vx 570 Countertop Solution Hard Drive
What is an dependent variable
All values that arise as influenced by changes in the values of other variable. Or, Dependent Variable is the observed factor.
If we have a Linear Function as
Y = mX + C
so,
Y should be Dependent Variable,
X as Independent Variable,
m as Coefficient and
C as Constant.
Aug 30, 2016 | Office Equipment & Supplies
What is an independent variable?
An independent variable is not directly or indirectly related to another
What does responding variable mean?
The responding variable is another name for the dependent variable.
On a graph, the x variable is the independent variable and the y variable is the dependent/responding variable.
I remember the difference between the two in that the dependent variable depends on the independent variable. For example, for teenagers, in height versus age, the age would be the independent variable and the dependent variable would be the height. We would expect as teenagers get older, they are taller.
Let me know if you have any questions.
Good luck.
Paul
Sep 02, 2015 | Miscellaneous
What is a dependent variable
  1. Dependent Variable: A dependent variable is what you measure in the experiment and what is affected during the experiment. The dependent variable responds to the independent variable. It is called dependentbecause it "depends" on the independent variable.
Feb 03, 2015 | Office Equipment & Supplies
What is the definition for controlled variable?
You have either constants or variables. Constants are things that does not change. Time is a constant - you can't move forward or backward in time.
Variables are parameters that change. Some variables are fixed, others can be controlled.
A controlled variable is a variable that can be changed at will or according to circumstance.
For example, if you have a radio with a fixed coil / tuning capacitor which can receive only one station, the variable (radio stations) cannot be controlled, it is fixed, therefore a fixed variable. A normal radio can be tuned to different stations, therefore a controlled variable.
The engine on a car has a controlled variable speed. A normal light bulb is controlled by a fixed voltage, until you build in a dimmer switch, which now makes the voltage variable, and controlled.
Nov 07, 2014 | Cars & Trucks
When conducting an experiment, a researcher usually has a dependent and independent variable. The independent variable is the variable that can be changed or manipulated (think of it as a cause). The dependent variable is the variable that depends on the independent variable (think effect).
For example, if you wanted to test whether or not taking Advil affects the length of a headache:
  • Taking Advil (or not) is what you can manipulate. It is the independent variable.
  • Headache duration is the dependent variable. The results depend on whether or not Advil was taken.
Sep 16, 2013 | Finance
I have a project and i don't know what independent or dependent means
For example, if you wanted to test whether practice improves an athlete's performance (lets say number of touchdowns):
  • Practicing (or not) is what you can manipulate. It is the independent variable.
  • Number of touchdowns is the dependent variable. The results depend on whether or not the athlete practiced.
Sep 07, 2013 | Finance
What is the variable frequency drive?
VFD is a device used for speed control of 3ph induction motors & automation process control
Mar 18, 2013 | Hitachi Variable Frequency Drive Inverter
Verifone vx610
#1 You need the Vmac and Comserv applications that were deleted when you cleared memory in order to perform an IP download. Without them you can only perform a dial only download.
#2 The programming for your VX510 will not load in your VX610 because they doth identify to the server as different models. If you did get the vx610 to connect and request your vx510 file you would only recieve an error "Application not configured" or "file not found"
Pro Tip: You can still clone VX terminals reguardless of model with the correct cable. Enter system mode and press 0 the # or 0 then * to send and recieve. This would put the application from the vx510 into the vx610 but your vx610 may not work through a com method other than dial depending on your processor.
Feb 10, 2010 | Computers & Internet
VeriFone Vx 570 Countertop Solution Hard Drive Logo
203 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
