How do I replace door lock/switch assy in kenmore 44082 washer
My Kenmore #44082 recently began to not spin when supposed to. Ran a diagnostic check and received the following error code: E47 - Board thinks the door PTC circuit is open in spin. After a great deal of research online, I find that the door lock assembly is probably bad. Evidently, this is quite a common problem in this Kenmore model. We would like to try this fix on our own as it appears the part should run only about $50 or so. Problem is, we have no idea how to access the door lock assembly. Can anyone give us detailed, step by step instructions and save us at least $200? Thanks!
  • CONNIE BLAMER Mar 11, 2009
    Hooray and thank you for your assistance "aborcass". We can finally wash clothes at home again! Your instructions were spot on and my husband did this repair is about 5-10 minutes. (You really are a guru!)
    President:
  • Washing Mach... Master
  • 2,651 Answers
Easy repair, somply open the door, and l;ook behind the rubber boot, youll see a metal band holding it to the fornt of the machins( spring loaded at very bottom) roll the "clamp"wire off andremoveth righthand side of the boot, youll need to unscrew trhe 2 phillips screws holding the latch assy on nad it will slide right put, probly 3 connectors( youll have enough wire to almost pull all the way out.. replace with the new latch(wires only plug into correct spots, you cant do it wrong). resecure the latch and roll the rubber boot back over the front lip. rescuring the metal clamp may take a little patience, but get a third hand if available.. starting at top strecth over both sides and snap spring over the bottom. easy repair take youtime youll be fine!!
Posted on Jan 25, 2009
Kenmore HE Washer Model 11046472501 - add a garment light stays on with the door lock light on at the same time. We have unplugged the machine and ran the drain and spin mode, but he washer won't
Not sure if these will help or not:
http://www.youtube.com/results?search_query=Kenmore+HE+Washer+diagnostics&oq=Kenmore+HE+Washer+diagnostics&gs_l=youtube.12...4054.11443.0.13769.12.12.0.0.0.0.236.2449.1j0j11.12.0...0.0...1ac.1.93rgz26enSw
Jan 26, 2013 | Kenmore Ap4327152 Motor Control Board for...
Kenmore front load washer goes through wash and rince cycles but will not spin
These are symptoms of a broken door lock and switch assembly and the only viable solution is replacing the said assembly if no issue is found with the wire harness connections. The machine will not advance to the spin cycle unless the door lock spin switch is activated. This is a safety feature to prevent the door from opening and avoid injuries during the high-speed cycle. Replace the door lock and switch assembly and it should solve the problem. Click on the link below for the detailed instruictions on how to replace the door lock and switch assembly. The part number for the door lock and switch assembly of your machine may be different but the instructions still apply.
Replacing the Door Lock and Switch Assembly on Kenmore Front-Load Washing Machines
Mar 05, 2011 | Kenmore Washing Machines
Kenmore 44052 will not spin. Replaced door switch still will not spin. Ran diagnostics (code E43) so I replaced motor control board still will not spin. Could not get out of diagnostics so I replaced...
Have you pulled the pump and checked for obstructions? There may be something in the pump itself; you will need to check that...
If your problem can't solve, keep in mind that the error codes means physical wrongs, so, E43 is a door-locking problem or "board comunication problems".
I hope this helps.
Sep 30, 2010 | Kenmore 44042 Front Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
No spin or drain on Kenmore 25972
Unless this is different from any washer we have ever owned, the door switch doesn't prevent or permit the pump from working but only the spin.
Go to the Sears website and follow links to the parts section. Enter your complete model number and there should be a detailed parts illustration that would allow you to learn where it is located.
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
640 people viewed this question
Top Washing Machines Experts
