Question about Makita 5090d 96 V 338" Cordless Circular Cutting Saw
Makita 5090d will not start
Battery good, will not start
Hi. I have a makita 08070 hammer. when I will start this the power light is work but machine not work
Australia Drill Battery offers a complete and comprehensive product line of high quality MAKITA power tool batteries. Our MAKITA drill batteries are designed to be fully compatible with the original cordless tools. http://www.drill-battery.com.au/batteryshop.php/makita_power-tool-battery.html
May 09, 2017 | Makita Drills
Makita battery
Check that you have the correct battery in the charger as the charger will not charge any type of battery, only the battery type listed on the panel.
May 06, 2013 | Electronics - Others
Cannot get saw blade off a makita 5090d saw.
Lift the guard and clamp the blade in a vice using a pair of soft jaws and then undo the bolt.
Jun 10, 2012 | Makita 5090d 96v Cordless Trim Circular...
My Makita cordless angle grinder (new, used once) BGA452 wont go, it starts then the overload light comes on and it stops? changed battery, still happens.
Obviously too late for you, but it may help others.
I had the same problem with a new Makita 18v lithium grinder and this worked.
Remove battery, remove brushes. Using good quality cotton buds, dip in Methalated spirit and insert into hole for brush down to armature, slowly rotate head of machine. Change cotton bud and repeat process, then clean the brush heads. Re-assemble and try. Note: Meths will dry completely leaving no residue, unlike turps etc.
Jul 16, 2011 | Makita Bga452 Lxt 18v Liion Cordless Angle...
One question please, I have makita cordlless
according to the schematic I saw yes you can and I think that you will be pleased with its performance, their operator manual even lists the weight of tool with this battery. Makita has a 1 year limited warranty on the Li-Ion battery that you might want to consider if you have the receipt.
May 11, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
Some manufacturers put some chip on their battery so it can be identified by their charger. If you use a generic battery often, it will not charge or work properly. LG does this with their phone batteries! So you have to use another charger to charge them.
Jul 07, 2017 | Makita Drills
Can my makita bl1830 battery be repaired if it does not hold charge anymore
This battery has a known design defect that causes premature failure. The battery is still probably good, but the safety circuit n the battery spuriously locks it, due to a bug. Once locked, it won't charge in the Makita charger (flashing red and green lights). Makita knows about this problem but so far is not actively recalling the batteries. Makita will replace the pack if the charge count is under 150 (some people say 300?) regardless of warranty status, but you have to take or mail it to a Makita Service Center -- the dealers won't handle this unless it's in warranty.
http://www.makita.com/en-us/Modules/Service/ServiceCenters.aspx
If Makita won't fix it, you can try to repair it. If the red and green lights are flashing, the battery is probably locked and cannot be repaired in a way that will let it be charged in the Makita charger (but it can be charged in off brand chargers). Buy a clone charger on eBay for $60 and try it. If it charges, just use it, no repair needed.
Be aware that lithium batteries do lose capacity permanently at a rate of about 20% per year. So, 3-6 years is about the best battery life you can expect - from date of manufacture, so if it sat in the store a while that adds. Makita derates the cells to allow for some shelf life (down from 2400 Mah to 1500 Mah rating).
If the battery is weak, and only gives brief usage, you can replace some of or all of the cells in the battery. These are expensive and worth repairing. See this video:
http://www.youtube.com/watch?v=Z5taguEdlkY
If just 1 or 2 cells are weak, you can replace them with the same Sony 18650 size 2400 Mah capacity battery, green sleeve. The Sony's are not sold retail, and are hard to find other than from another Makita pack or from some laptop packs. If more are weak, you're better off just replacing all of them with new 18650 2400 Mah (or higher) batteries with tabs. Look for Tenergy or other quality brand.
Hope that helps.
Nov 02, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My makita 18v 2.0 battery won't keep a charge makita 2.0AH battery showing charged on charger loses charge as soon as i start drilling
It appears that your battery is worn out. They will charge, but miminally. If it is a nickle cad battery, and relatively new, you may have a memory problem. Try draining the battery completely several times and recharging each time. Be sure the battery is completely dead before recharging.
Jan 26, 2009 | Makita BHR200SAE Cordless Rotary Hammer
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Jul 03, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 5090d 96 V 338" Cordless Circular Cutting Saw Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
