Question about Nilfisk Vacuums
Switch on nilfisk GMCA02
On/ off switch broken
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
How do I put a new wheel on nilfisk a300
by the picture of the
nilfisk a300 replacement wheels
its a pull off clip on type design
the axle should be metal
it will need some force to remove the old wheel
may even try to break the old wheel off in pieces
Sep 07, 2016 | Nilfisk Vacuums
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
My Nilfisk GU305 cuts out after a few minutes use
You are probably right. There is not enough air flow around the motor. It uses the air from the vacuum as the cooling air.
There is a secondary filter after the first filter bag. You may think the bag is not full and don't think you need to change. Sometimes the material you vacuum is so fine that it will clog the filter bag. I've done it vacuuming sheetrock sanding dust. Then just below the main filter is the secondary filter. Depending on the age and amount of use, there could be other problems. Motor brushes about to fail. A wire connection that separates as temperatures rise. Then reconnects when "cool". Plug end may be a problem. Its connection to the switch. The switch it'self could be.
Mar 21, 2015 | Nilfisk Vacuums
Nilfisk hoover will not switch on
Start with the basics, check for a reset button on the motor housing, make sure the circuit that the appliance is plugged into not a gfi circuit
thats been tripped. Keep in mind that when working with any electrical
-know your kimits!
Aug 16, 2014 | Nilfisk Vacuums
Power keeps turning off on Nilfisk vacuum
What kind of vacuum is this? If it is a pushbutton switch you may need to replace the switch.
Oct 24, 2013 | Nilfisk Family Vac Bagged Canister Vacuum
How do I open a Nilfisk Action Plus vacuum cleaner?
l have a question but no answer for your question--is switch actually broken or unit will not power on?
Dec 17, 2012 | Vacuums
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Not working,need assistance from anybody or cheap parts.thanks
sounds like the trigger switch is stuck.try to spray a little wd40 up into the switch and work it ,maybe it will free up.if not the switch is probably bad
Apr 29, 2009 | Vacuums
Vacuums Logo
74 people viewed this question
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
