Question about Pool & Spa
PENTAIR WHISPERFLO 1.5 HP POOL PUMP PUREX 011773 WF-26 motor replacment
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: What are the specifications for
Take the cover off of the capacitor...it is the bump on the top of the motor...then look on the capacitor and find the numbers that end with mfd. that is the size or rating of the capacitor...also then look for the voltage of the capacitior...you need to match that also...there are so many different motors used, even for the same pump that it is hard to say for sure what you may need there with out looking at it.
You can do that and then you know you are getting the correct cap for your motor...
My guess is that you are looking for something in the range of a 20mfd 370volt cap. but please check it out for sure they vary alot!!
heatman101
Posted on Aug 28, 2010
Turned off breaker and pump will not come back on. Not start capacitor
might be a bad breaker, test power at motor you should have about 220v on the line 1 and 2 terminals if the motor is set to run on, there is a daigram on the side of the motor for refrance
Jan 07, 2015 | Pentair 011773 WhisperFlo WF-26 High...
Why does pump trip breaker everytime it is turned on?
try turning the shaft from the back with it off it might be rusty then try if it still does that you need a new pump motor or pump
Sep 03, 2014 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
How to replace a pump seal
if leaking probably ruined bearings sometimes still leak replace whole unit
Apr 12, 2013 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Noise and leaking
leaking seals and they wrecked the bearings replace pump
Apr 10, 2013 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Pentair wf26 pool pump motor noise
try standing it on a piece of inch thick rubber type foam and see what happens
Apr 12, 2012 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
I just had someone look at my WF-6 pump because of a loud whining sound. Everything is running fine, but noisy. They said they believe the bearings are going out and suggested replacing the entire unit for...
You can have the bearings replaced for about $100. It is something that you will have done by a professional. Consult with a local pool store and they should be able to direct you to someone that does that.
Dec 29, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Pentair 011773 runs 10 seconds then throws the breaker. ??
Thermal overload or overheating. Motor needs to be replaced or rebuilt. Might want to make sure the breaker isn't bad, but most likely the motor is bad. If you are in the Phoenix Metro area you can contact me at info@wefixuglypools.com for more help.
Dec 28, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Pump switching off for about 10 -20 seconds, then back on. Hapens about every hour
the little house on top of the motor has a capacitor in it 90% of the time thats whats wrong with this motor it's eather a 30 or a 35 mf .
pull this off the motor and search your area for pool pump motor repair, free testing ,use your zip code in the search, ask if they can test a capasitor for you.. wait to take capacitor off till the motor cools off
about a $20.00 fix
hey if'n i was of help vote..thanks ..jay
Aug 08, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
