Question about Hampton Bay Dryers
Hampton baylight kit cap
Model C552W
I need a replacement LED light bulb or kit for my Hampton Bay fan model number AM215-BN. Where can I get one?
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Light-Kits/Hampton-Bay/N-5yc1vZc5t3Zp4
Aug 14, 2016 | Hampton Bay Dryers
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
My light kit wire is not connected
Blue, is usually international color for the NEUTRAL wire. EUROPE BROWN==PHASE BLUE===NEUTRAL Green/Yellow stripe==EARTH. (Most important wire)
USA. BLACK==PHASE WHITE==NEUTRAL GREEN/BARE==EARTH (Most important wire)
Mar 28, 2010 | Hampton Bay 24002 Ceiling Fan
Can you replace light kit on Hampton Bay ceiling fan, Model-Cessna
Yes..
There are a bout three screws that hold the light part to the fan.
Make note of the wiring before you disconnect it also.
Remove the screws and the wiring will be exposed as the light part drops down...
Check the diameter of the light parts and find a new light kit that will fit it...
The Hampton Bay fans are exclusive to Home Depot, so most any of their light kits will fit, but any kit the right diameter will work..
Heatman101
Mar 05, 2010 | Hampton Bay Cessna 04313 Ceiling Fan
I need to install a Hampton Bay ceiling fan Model AC552 but I have no instruction manual. Can I be emailed one.
look into the internet for download of that manual model with the full name of product for instruction manual. try that.
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
Trying to find light kit for Model 56-ANTm Flemish Brass
check the kit at home depot, get name and phone number of manufacturer and call them to see if they can supply the glass that you want.
Dec 13, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Dryers Logo
22 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
