Question about Frigidaire Dishwashers
I have a frididaire fdb520rhs2a that will not start.
This is a new Frigidaire Dishwashers FDB520RHS2A but I plug in the 240V power then the machine not work. Can you help me. Thanks.
2 Suggested Answers
  • 160 Answers
SOURCE: I have a frigidaire fdb520rhs2a that will not come
Remove the bottom access panel in the front of the dishwasher. In a plastic envelote there is a technician diagnostic sheet. Read where it says start auto diagnostic mode. There are like 6-10 buttons you have to hit in a sequence. The sheet will also give you what is wrong and what to replace/ reset. If you cant enter diag mode than disconnect power remove the door panel and access the console. Open the control board and see if there is a 20amp fuse near the control board test this. This fuse is designed to protect the control board. If bad replace. If you have any more questions please comment me back.
Posted on Jul 30, 2011
I have a frigidaire fdb520rhs2a that will not come on I checked the circuit breaker and it's on. I ran the hot water for 10mins and still nothing.
Jul 30, 2011 | Frigidaire Dishwashers
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
My 4 year old frididaire dishwasher does not
Check the drain plug for some blockage ( small sock or lint.
Make sure it leans slightly back and not forward by adjusting front leg wheels.
Please rate my help++++Thanks for using FIXYA
May 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frididair GLD2250RDC0 The lights on the selection buttons (Normal cycle, pots and pans, no heat dry etc) flash when pressed. When the start button is pushed, it sounds like the cycle is starting, but...
if this is a older model 4 to 5 yrs I would look at the door inter lock they have changed this ( it has been a problem . ) second the p c prosser will probley have to be changed . mm
Dec 04, 2009 | Frigidaire 24 in. GLD2350RCC Professional...
Will not fill with water
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
May 27, 2009 | Frigidaire PLDB998A Built-in Dishwasher
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
ASKO D1706 ... where is the control temp. for element for more dryer ?
you cant ajust the temp its thermostat control,if you want it to dry at end of cycle use rinse aid and open the door at end of cycle to let the steam out.you only have a 55 or 65 wash button on right side next to timer knob.
Feb 03, 2008 | Asko D1706 Built-in Dishwasher
No power to dishwasher
depends on the sequence. many, but not all, dishwashers start with drain to get rid of the slops. if yours starts with fill, then no water supply will prevent progress.(you should be able to hear a low hum which is the valve energised) check also that the door is closing properly and latching. better to use cold water fill not hot
May 09, 2007 | Frigidaire GPDB698SSBK Dishwasher
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
