Question about Emerson EWR20V4 DVD Recorder/VCR
I can format dvds or record what is wrong - Emerson EWR20V4 DVD Recorder/VCR
    Problem Solver:
  • 7 Answers
Make sure that when trying to format dvd's you are using the bottom portion of the controls. i know it sounds silly, but the center arrows are for dvd playing and control....ff...rw....play, and the lower controls are more functional.
i'm not sure, but if you put in a blank dvd-r disk, it will allow you to format after going to the "setup" then using the lower arrow moving the selection over DVD. format is allowed in that selection. If you have already recorded on the DVD-R i don't believe it allows you to format, it only allows you to edit or finish.
i'm not sure how the dvd-rw works as i haven't used one in a long time. in theory, you should be able to format a DVD-rw.
hope it helps.
Posted on Feb 24, 2009
3 Suggested Answers
SOURCE: DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Posted on Feb 10, 2008
  • 4 Answers
SOURCE: Will Not Format DVDs
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid Maxell brand. Usually any other cheep brand will work.
Posted on May 30, 2008
Dvd player unlock codes
This can indicate a bad disk or a disk not recorded in DVD format, you can check the disk status and format in your computer with DVD drive and a player software as VLC.
Aug 16, 2014 | JVC Televison & Video
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
I have an Amoisonic 9100 DVD player. The problem is it works fine with some DVDs but other DVDs will not play, I get the message "wrong disc". There is no pattern to this that I can think of, all...
Don't worry your DVD player is fine .DVDS disc burners have different formats of recording . Not all DVD players can read all formats .
peace Iam out .
Jan 10, 2018 | Televison & Video
I'm having problems formatting discs for Panasonic EZ47 DVD recorder. Keep getting "formatting unsuccessful" message.
Now here are the types of DVDs that you can record to DVD-RAM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Now the only types that you can format are DVD-RAM, DVD-RW, DVD+RW
So first make sure you are not trying to format the wrong type of DVD. If you are using the correct type then you might want to try a different brand. Sometimes certain brands of DVDs have problems with certain players. You can also try updating your player's firmware and see if that corrects the problem also.
Jan 01, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Will not record or read disks other than pre recorded dvds
make sure the format of the dvd is + R or +RW, if it is -R or -RW, will not work. that dvd player can record to a certain format. if you got a stack of dvds, you should see it on the label.
if you have +, let me know, and we'll troubleshoot it more.
Oct 18, 2009 | iLO DVD Recorder DVDR05
Feb 09, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Emerson EWR20V4 DVD Recorder/VCR Logo
124 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
