Question about Vivitar V5000AF Slide Projector
Fotocrest 53 2 x 2 slide projector used airequipt circular magazines. Need new projector for magazines.
Will my magazines fit this projector?
Slide magazine to fit prinzauto
Hi these Prinz slide projectors are made by the same Australian company who makes the Hanimex brand ,they use both the 120 rotary mags and the 36 or 46 slide trays,the Prinz brand are made for the British market,ive bought a great Prinz concord auto still in its orginal box,where about do you live?
Jun 26, 2012 | Office Equipment & Supplies
We have Rollei Projector P37E, where can we buy a slide tray for the same ?
Impossible to find new ones. They only fit this model and haven't been made in decades. Used camera specialists like KEH in Atlanta, GA might have some.
Jul 13, 2011 | Rollei 66 Dual Slide Projector
Replace lamp epson emp 53
put a flat screwdriver into slot between end of the lamp cover and the body of the unit.
slide the cover out until the arrors line up on each side. then lift the cover out.
undo the 2 screws holding the lamp unit in.
lift out the lamp unit.
do the reverse to install the new one
Jun 23, 2011 | Epson EMP 53 Multimedia Projector
The slides appear to be dropping to far down so when viewed you see the top of slide (cardboard) and top half of picture- thi swas given to me used and I dont have a book - it is 300AF
Try using a full thickness plastic slide mount. Some card slides are so thin that they miss the slide support when being dropped down from the magazine. Some magazines are designed specifically for card mounted slides whilst other are for glass mounted slides. Types shouldn't be mixed for correct and consistent operation.
Feb 14, 2011 | Elmo Projectors Omnigraphic 301 Slide...
The slide magazine will not advance despite the arm moving in and out
If you are in the USA we are the service center for Braun projectors. Call us at 800 735-4373
Jan 15, 2011 | Braun Novamat 130 AF Slide Projector
I bought a used Elmo TRV-35H 35mm projector. The camera works fine, but the tray only moves in reverse when I press the forward or reverse button. And after moving through a few slides it then moves...
Remember, mains voltages exist within the projector and thus the unit MUST be disconnected from the supply line whilst carrying out any servicing.
The reported fault sounds like sluggish operation of the advance/reverse mechanism. Lubricants used in the past tend to age and dry out so that the mechanism doesn't function correctly. IF YOU ARE CONFIDENT TO DO SO, remove the top of the unit and locate the slide mechanism. Carefully clean with cotton buds dipped in pure electronic cleaner and then re lubricate, using an oil dripper with the finest industrial sewing machine oil - emphasis is on a 'drip' of oil on the moving pivot points. Put the top back on and try again.
Problems with remote controllers are suually associated with tarnished contacts either in the hand unit or the projector. Once again, the contacts can be carefully cleaned and all should be well once more.
If you are using Kodak Carousel magazines, make sure you are using the correct magazine for your slides - cardboard or glass mounts. Don't mix slides in a magazine, as this can also cause problems.
Dec 13, 2010 | Elmo Projectors TRV-35H Slide Projector
AIREQUIPT 1135 - focus works but can't get the auto slide to work
If the slide tray doesn't advance or reverse using the on-board or remote control buttons, chances are that: 1. You have a broken mechanism drive belt. 2. You have a jammed slide change mechanism module or 3. The mechanism trip contact is trapped behind its mating contact on the mechanism camshaft.
All of these problems require service documentation & special tools. My recommendation is to find an Authorized Repair Dealer.
Oct 05, 2010 | Kodak Carousel 4600 Slide Projector
Vivitar V5000AF Slide Projector Logo
61 people viewed this question
Top Vivitar Office Equipment & Supplies Experts
bhargav
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Vivitar Office Equipment and Supply Expert? Answer questions, earn points and help others
