Question about Ridgid 25648 Wet/Dry Vacuum
Rigid wet dry vav wont suck only blows - Ridgid 25648 Wet/Dry Vacuum
2 Suggested Answers
SOURCE: how do i go from
can I run my sears shop vac without the paper bag, for dry pickup?
Posted on May 02, 2009
How do I get the Rigid Wed Dry Canister vac to start?
Check the plug......I have a Rigid and have replaced the plug.
Regards,
Dennis
Aug 21, 2014 | Rigid WD1278 Canister Wet/Dry Vacuum
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Why is my wet dry vaccum blowing and not sucking?
The clog or the bag or canister is full. Clean or replace filters.
First of all, make sure you put the hose on the suction port. If it's blowing where it should be sucking, the polarity of the motor is backward; the wires are hooked up wrong.
Feb 25, 2012 | Vacuums
The vacuum is blowing instead of sucking
Your in the wrong hole tank is the sucking motors the blowing.
Feb 27, 2011 | Craftsman 17026 Wet/Dry Vacuum
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
Eureka 2812 shop boss wet/dry..water is being sprayed out of the
je ne trouve pas un magasin ou je puisse acheter des filtre a poussiere
Jun 20, 2009 | Eureka 2812 Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Husky 6 gallon dry/vac wont **** in air, only blows air out
Maybe you have the vac hose plugged into the blow out port.
Nov 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Ridgid 25648 Wet/Dry Vacuum Logo
Top Ridgid Vacuums Experts
ken skalski
Thomas Perkins
Thomas Perkins
superjulimaximo
superjulimaximo
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
