Question about Canon PowerShot S95 Digital Camera
Is it possible to fix bent lens assembly on dropped s95
4 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Bent lens
From what you describe it doesn't sound good. But here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Mar 09, 2008
  • 11967 Answers
SOURCE: I dropped my camera when
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 22, 2010
t00nz
  • 4738 Answers
SOURCE: Hi This morning my canon sx200
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Posted on Sep 25, 2011
Lens repair ef
I doubt it is possible to repair. These lenses are mostly made out of plastic pieces. There is probably something broken and/or bent. Lenses are manufactured with extremely great care. When a lens element is only a millimetre or two out of alignment you probably will get faulty images (flare, unsharp, focus shift, etc).
Take it to a repair shop and have them examine the lens if that's free of charge. Without photo's it is hard for me to judge if its total loss or not.
Jan 02, 2014 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Lens error canon s95
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 24, 2011 | Canon PowerShot S95 Digital Camera
My camera was dropped and now there are two little pieces of the inside of the camera inside my lens and it won't zoom. is there a way i can take it apart to try to fix it?
assembly of the lens unit is disterbed,lens operation isnot possible,inside optic rings may be broken,so replace with anew lens unit
Mar 04, 2010 | Fuji FinePix F650 Digital Camera
My camera died with the lens out. then the next day i recharged it but it wasn't turning on. I noticed the lens was bent out so i pushed it in and it went in easily. Now when i press the power button the...
Was the camera dropped? Bent lens is not a good sign and possibly needs to be sent in for repair. If the cost is too high to replace (unless they fix them under warranty) than it's time to replace the unit unfortunately.
Nov 08, 2009 | Samsung L200 Digital Camera
Zoom error
The lens got out of track. Try to have them back by forcing gently the lens in ou out with your fingers. If they are bent, force them straight. Hope it helps.
Nov 21, 2008 | Fuji FinePix A600 Digital Camera
Lens got dropped mount broken
How much of the lens do you need? I have a couple that i picked up as parts
Oct 24, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Lens problem
Dear Customer,
When you say the lens barrel is bent, do you mean that the camera won't turn on ?, or the lens barrel is just bent and it looks outlandish. However if it's not turning on follow these steps:
1) Try to gently re-position the barrel, and make it more stortionate.
2) try to recharge ( or get new batteries ), and see if the lens will withdraw.
Unfornately, when you drop a camera, many warranties are voided, and you have to pay to have it fixed, but i doubt it would be that much money to fix.
Please rate this solution.. Thank You..
Jul 11, 2008 | Casio Exilim EX-S500 Digital Camera
FD 200 MAVICa won't focus
Do yopu remember if the front (lens) area received a hit, even though with low force?
I am asking because in most MVC-FD cameras I opened to fix them about the same focus problem, I did find that an internal bracket that holds the lens assembly, it was bent due to an external force or hit in the front.
The bent bracket really was not the problem. The reason of the focus issue was that when the bracket was bent, the flat ribbon cable of the lens was pressed against a mounting screw, causing that the flat ribbon cable was damaged (punctured) affecting 2-3 traces of it, and preventing the lens to operate properly.
Repairing such problem requires to either replace the damaged flat ribbon cable, or the whole lens assembly.
You can get your hands in a broken camera with good lens assembly, and swap the parts.
Best regards,
Feb 25, 2008 | Sony Mavica MVC-FD200 Digital Camera
Canon PowerShot S95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
