Question about Toshiba XD-E500 DVD Player
Won't turn on
Dvd player won't power on
Kenwood 6.1 dvd screen won't turn on, but reset
It appears that you may have battery power but, no accessory power. Check you radio fuse in the vehicle and, behind the radio.
Feb 06, 2013 | Car Audio & Video
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
My jvc dvd player xv-thc50 won't turn on
if your dvd player has no any power indicator at the front, the first place to be checked will be the power supply. look for a blown fuse bad component parts like shorted diode and an open resistance.
Oct 15, 2012 | JVC Televison & Video
I have a ripspeed DVD 720 when I wired it in the power button just flashed red for a bit and that's it it won't turn on or do anything?
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Oct 06, 2012 | Televison & Video
Won't turn on
see this causes and fix it. God bless you
  1. Power outlet, wall adapter, or batteries are dead (as appropriate).
  2. Damage to line or wall adapter cord or plug.
  3. Bad connections or faulty component in power supply (including blown fuse).
  4. Defective microcontroller.
Sep 23, 2012 | Samsung DVD-H1080R DVD Player
It won't turn on
is there power to your dvd if there is then maybe turn your disc over and make sure it is a blue ray disc
Sep 19, 2012 | Sharp AQUOS Blu-ray Disc Player
DVD player is broken and won't open and I have a disc stuck in there
you have 3 alternatives for open:
1) with the button eject or close/open
2) remote control. button open/close or eject
3) with small knife pull out the carrousel for to bring the disk, with carefully.unppluged the power cord.
otherwise you must go to the repair shop TV for fix it
God bless you
Jul 21, 2012 | Philips Magnavox MDV453 DVD Player
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
Toshiba XD-E500 DVD Player Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
