Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Vibration in brake pedal
When tractor is moving it runs good but excessive vibration in brake pedal
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    well im waiting for answer.
  • JERRY ABELL
    hello! vibration brake pedal;well i need to know what type of transmisson you have,hydrostic or manual.does brake pedal vibrate only when blades engaged or only while driving tractor,or both.please let me know.thank you.MrFixIt.
  • 24 Answers
You have a flat spot in your drive belt or a chunk out the belt .
good luck
Posted on Feb 08, 2009
Lawnflite 908lh has excessive vibration when mowing,engine runs fine-machine is brand new,and engagement is via tensioner on the cutting deck,not a pto.
Jerry, could be a bad belt, pulley, blade,etc. Take back to place of purchase for repair under warranty.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
MTD Products
lawn tractor mower deck excessive vibration ShopYourWay
Mower deck excessive vibration
http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=lawn&msg=1098
May 22, 2016 | Garden
Excessive shaking break pedal
Check your brake return spring for being wear, and check all your pullies if you have one with a bearing out it will start wobbling causing vibration in the pedals.
Oct 30, 2015 | Garden
Can bad 02 sensors cause the engine to vibrate and make a humming noise? or bad motor mounts
Bad O2 sensors affect the fuel/air mixture. Vibrations can be caused by many sources, hard to diagnose here. To test the motor mounts. apply the parking brake, open the hood. Put the car in drive and step on the brake with one foot while applying full throttle with the gas pedal. Watch for excessive engine lifting on one side. Be careful not to have the engine fan to contact the shroud. Now do the same in reverse. If the engine lifts excessively, your mounts are shot. If the engine stays put with only a slight movement from torque, then the mounts are good.
Mar 07, 2015 | 1999 Saab 9-3
I have a Husqvarna YTH2348 that I bought from Lowe's last summer. As I was mowing today it suddenly started to vibrate excessively. I believe the problem is in the transaxle. When the brake is engaged...
There are usually one or two idler pulleys on the belt that runs from the engine to the transmission. Check those, more than likely one has gone bad. the should spin freely with the brake engaged, and the should not wobble.
Sep 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Riding Lawn Mower 46 Cut model #454140010G MOWER will not ingadge
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Jul 17, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I hah a 140 tractor but the brake/clutch pedal only moves about 1" and dose not seem to do any thing except when I go to high revs the whole tractor shakes and depressing the brake pedal hard stops...
It can be problem with safety interlock circuit, check the brake / clutch pedal itself.Check the pedal linkage if its bent or bound up or loosing pressure. ------- Click this link for more help:--- http://technoanswers.blogspot.com/2011/06/testing-brakeclutch-pedal-switch-on.html --------- This should help.Thanks.Helpmech.
Jun 06, 2011 | John Deere Garden
Mowing right along and suddenly the tractor won't go move
it's 1 of 5 likely things
The drive belt from the engine to the transaxle is totally slipping or broken
The linkage from the control pedal to the transaxle is faulty.
The transaxle is broken (not user fixable)
The by-pass rod is pulled out
The brake pedal is pushed or the linkage is stuck in the "brake" position.
Jul 11, 2010 | John Deere 22HP Hydrostatic 42" Riding...
My craftsman 17hp lawn tractor shutters bad when releasing the clutch pedal. is it the clutch and where is it located?
Its not really a clutch, clutch/brake pedal when pressed will release belt pressure which stops pulley from turn axle. When predded all the way down it mechanically applies brakes. The vibration is from a bad pully that the drive belt rides on or a bad belt. Look for chucks of belt missing.With engine off put on parking brake and manually wiggle each pulley that drive belt rides on to see if there is any play. No play should be present. Good luck.
Mar 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
422 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
