Question about Polaroid CAA-03040S Camcorder
Locate battery compartment
Where is the battery compartment for this camera I can't find it. HELP
  • 98 Answers
On the side
Posted on Jan 25, 2009
XX14v2 how do i open the battery compartment?
If you look in the manual, you will find the cover to the battery compartment is located on the RH side of the camera as it faces away from you (i.e. in the normal shooting orientation) - behind the hand grip.
The compartment cover will probably slide towards the base of the camera so that the batteries can be inserted, in the correct manner of course, so as not to compromise the electronic circuitry.
Dec 03, 2017 | Cameras
Where is the battery in the JVC CP6U Adapter?
I don't know if you found the battery compartment yet but it is located on the left side of the adapter, right above the red rectangular button.
Nov 16, 2012 | JVC CP6U Adapter
My digicam won't start
There could be a couple of reasons why your camera would not start.
Before considering it to be defective, verify that the camera has batteries inside and that these batteries are charged. To do this:
  1. Locate and open the battery compartment.
  2. Identify the type of batteries needed and purchase new ones OR
  3. Recharge the batteries with the recharger provided.
  4. Place the new/charged batteries inside, closing the battery compartment.
  5. Try to turn on the camera.
If the camera still doesn't work after verifying that the batteries are in order, remove the memory card and any other accessories that the camera may have and try turning it on again.
If still the camera won't turn on, one last step can be performed if and only if your camera uses standard batteries (AA or AAA). If this step is performed incorrectly, you could short circuit the batteries, which would discharge them. This procedure will not damage the camera if performed correctly. Please pay attention and do exactly as explained:
  2. Remove the batteries.
  3. Place the batteries back inside in the opposite direction than the one indicated. If the position indicated is for the positive end first, place the battery with the negative end first. Do this process for all the batteries.
  4. Close the battery compartment.
  5. Attempt to turn on the camera. It will not turn on, but this step is necessary nonetheless.
  6. Open the battery compartment.
  7. Remove the batteries.
  8. Place the batteries in the correct position according to the indication.
  9. Close the battery compartment.
  10. Attempt to turn on the camera.
If the camera still does not work, it is likely that it is defective. At this point you should take the camera to an authorized service center.
Mar 30, 2011 | Cameras
I can not open the battery compartment! Have tried pressing the button located on the top but it does not open. Please help!
I don't know the SVP cameras but most battery compartments have catches which work by sliding them into the open or closed positions, rather than by pressing on them. Hope this helps!
Dec 28, 2010 | SVP Cameras
Help!!! i have a rented vivitar film camera from school.... 3800 N..... with a dead battery!!! i can't figure out where the battery is located??
The battery compartment is on the bottom of the camera. Use a coin to turn unscrew it.
If you need one, you can download a manual from
http://butkus.org/chinon/vivitar_cameras/vivitar_v3800n/vivitar_v3800n.htm
Nov 08, 2010 | Vivitar V3800N 35mm SLR Camera
Don't mean to sound like an idot, but don't know how to insert battery?!
The battery compartment is located on the bottom of the camera.
It has five raised bars to help you get a grip to slide it off.
It takes one AAA battery.
Feb 25, 2010 | Disney Pix Micro Digital Camera
Where is the battery located in the iqzoom ezy-r?
It's in the battery compartment in the right hand side end of the camera. You'll need a coin or similar to open the battery compartment cover (a round piece at the bottom).
Jan 05, 2010 | Pentax IQZoom EZY-R 35mm Point and Shoot...
How do I open the battery compartment on my son's fisher price camera?
The battery compartment is located on the bottom of the camera. You can use a phillips or flat head screw driver to unscrew the 2 plastic screws. Once unscrewed slide the bottom piece out.
Jun 08, 2009 | Fisher Price Fisher-Price L8341 Digital...
Cannot open the battery compartment to change batteries
I give up...battery compartment so bad I'm returning the camera.
Jan 11, 2009 | Canon PowerShot A400 Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Polaroid CAA-03040S Camcorder Logo
71 people viewed this question
Top Polaroid Video Cameras Experts
Eric Sutherland
Tony Parsons
Tony Parsons
masud
masud
Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
