Question about Fuji FinePix F40fd Digital Camera
Fuji FinePix F40fd aoto focus
My F40fd has suddenly stopped auto focussing. When you press the shutter button halfway to focus it just goes blurry. The picture I see through the screen before I press the shutter button is as clear as. Sometimes if I put a bit of zoom on I can get a half decent picture but mostly they come our blurry. When pressing the shutter button halfway, I get a !AF in red on the screen which implies to me a tech fault with Auto Focus. Now, have I set something wrong in my settings or is this a manufacturing fault? I hope someone can give me an answer as its driving me nuts not being able to take photos and Im 1200kms from the city in the Australian outback. cheers Kerrigan
    Genius:
  • 2,985 Answers
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Posted on Jul 12, 2007
SOURCE:
My Fujifilm Finepix XP21 takes pictures but always blurry and not focusing? Any body
Have you tried focusing before you take a photo? To do this, press down the shutter button on your camera but don't push it far enough to take a photo. This enables the camera to focus on what it's about to photograph before you press the shutter button again and take the photo.
Nov 25, 2014 | FujiFilm FinePix XP21
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
When i take pictures with my canon powershot camera it is blurry and it is blurry normally too
NORMALLY YOU HAVE TO PRESS THE SHUTTER BUTTON DOWN HALFWAY, & WAIT FOR A GREEN LIGHT TO LIGHT, THEN PRESS THE SHUTTER BUTTON ALL THE WAY DOWN. THIS STEP SETS THE AUTO FOCUS ON THE CAMERA.
Aug 11, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Dec 30, 2009 | Fuji FinePix S1000FD Digital Camera
Camera will not focus correctly. when shutter button is pushed half way down the picture goes blurry, and if you take the photo it actually turns out blurry.
If you are taking close up photos, you might have to use the "macro" setting. The auto focus only works down to around 5 or 6 feet I think. I have an earlier model of that camera. I use mine for normal use and also close up for work related photos.
Nov 30, 2009 | Fuji FinePix S5500 Digital Camera
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Fujifilm FinePix S1000FD shutter button won't focus
There is an option in the menu to put camera on continuous auto focus. You must have the camera on manual setting to have this option available, but once selected, it should stay on in auto setting. It will wear the battery faster, but it should solve the issue you are having. Hope this helps!!!
Aug 03, 2009 | Fuji FinePix F30 Digital Camera
Shutter lag on fuji finepix s7000 - is there a solution ?
2 things - you could do 1 or both, depending on the photographic situation:
1) If you can choose manual focusing, select manual focussing & prefocus on subject. This eliminates the need to refocus. I do this lots with the S9500 model.
2) If you can shoot in manual mode, use auto exposure to see what shutter speed & aperture the camera selects when the camera is pointed at the ground (or other suitably lit spot). Change to manual exposure & set the aperture & shutter speed indicated by the camera in AUTO mode.
Once you do either or both of these you will get instantaneous shutter release.
Practise on unimportant subjects first and see how you go.
Apr 10, 2009 | Fuji FinePix S7000 Digital Camera
How can I point and shoot with my Fuji Finepix S1000fd? I press the shutter button and it goes through all sorts of focasing, Etc. What if I want a candid shot and want what is going on when I press the...
Be sure you are on auto. Pressing the shutter release down half way causes the camera to focus. This needs to happen to get a clear picture. Be sure you have adequite light or the auto focus will not work. You might need to set your flash to auto as well . Them by pressing the shutter release the rest of the way down, you will get a picture. But gain, you need to allow it to focus first, then take the photo.
Mar 08, 2009 | Fuji FinePix S1000FD Digital Camera
Blurry picture
I have this same problem. If I shut the camera off then on again it clears up. Someone from Fuji said that this is because the Auto-Focus is stuck on. They advised to half push the shutter button to release the auto-focus.
Nov 10, 2006 | Fuji FinePix A345 Digital Camera
Fuji FinePix F40fd Digital Camera Logo
179 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
