Question about Ice Cream Makers
Taylor y339-27 parts list - Ice Cream Makers
Taylor c712 with pumps one side sounds like it is pumping and looks like its pumping but when you use it there is no mix in the barrel
Hi Megan,
The first thing I would do is tear the machine down, sanitize and rebuild and properly lubricate everything. If you have a spare kit, you should install all new pump o rings and seals (Parts 4, 5, 6, 8 and 14 in the schematic). Hopefully, it is either improperly lubricated o ring, or a worn out seal and that will fix it.
The plastic pump parts do wear out over time (Parts 3 and 4) and so do the stainless steel pump sleeves (Part 1). If seals and lubrication don't correct the issue, you can start looking closer at the pump parts.
I have the tune up kit available here.
http://www.softserveparts.com/i-26471781-x49463-81tune-up-kit-for-taylor-c712.html
Schematics of the pumps are here with prices and part numbers.
http://www.softserveparts.com/p-37364-exploded-parts-views-for-taylor-c712.html
Soft Serve Parts C712
Jun 18, 2017 | Taylor Ice Cream Makers
Any maintenance issues on a taylor 430 frozen drink machine
The Taylor 430 is a solid machine. The only maintenance you need to worry about are:
1. Cleaning - Follow the instructions. Supplies are here.
2. Replace wear parts - Scraper Blades and Tune-up kit
The next most purchased part for that machine is the freezer door, but the good news is the new replacement is much stronger than the old ones.
Soft Serve Parts 430
May 12, 2017 | Taylor Ice Cream Makers
Does the taylor model 8756 put out a substantial amount more product than the 754?
Absolutely! The Taylor 754 and Taylor 794's are capable of 284 3 1/2oz. servings per side / per hour. The 8756 is capable of 426 of the same 3.5oz. servings. The 8756 packs more air into the product making it easier to freeze and reducing recovery time.
Soft Serve Parts Taylor Machines
May 07, 2017 | Taylor Ice Cream Makers
My taylor 152 only makes about 5 ice creams then won't produce any more for about 6 minutes ... why ??
The Taylor 152 is at the low end of output when it comes to commercial soft serve equipment. It is rated for 102 3.5oz. servings per hour, but only 4 3.5oz rapid servings before it needs time to recover.
Possible remedies:
When you need to serve several cones in a row, you can pull the feed tube in the top. That will help the product fill the cylinder a little faster.
You could always consider a used Taylor machine that has the ability to keep up with your demand. Soft Serve Parts Taylor Machines
Apr 07, 2017 | Taylor Ice Cream Makers
Looking for parts
have u tryed ebay or other aution sites or craige's list.
Apr 09, 2011 | Taylor 632-33 Ice Cream Maker
Taylor 8756 bottom cooler too warm
have you cleaned the coils in the top of the unit, the fridge one is the little one on the side.
Jul 07, 2010 | Taylor 632-33 Ice Cream Maker
Where can I find a repair man for Taylor Frozen yogurt machine? I live in Los Angeles, CA zip code 90024.
Call toll free number 1-800-665-1125 or www.dslinc.com and they will tell you who you can get in your area. The name of the company who services Taylor is DSL
Apr 09, 2010 | Taylor 632-27 Ice Cream Maker
Need a taylor C712 instruction manual
please sent me complete parts list manual for taylor icecream machine model # c 712-58 with all parts figure
Feb 07, 2010 | Ice Cream Makers
TAYLOR ICE CREAM MACHINES SPARE REQUEST
Get rid of this unit it is too old to repair.
Jul 10, 2009 | Taylor 632-33 Ice Cream Maker
Spares for Taylor 8756 ice cream machine
you must buy replacements from your local tatlor dist. 700-900$
You will find that responce from all of thier part suppliers carrier is a very well insulated company.
Jul 29, 2008 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
108 people viewed this question
Top Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
