Question about Magic Chef MCBR170 Compact Refrigerator
I have a magic chef 1.7 cubic compact refrigerator, it's been great, but I had quite a bit of ice build up on the little freezer compartment. I unplugged it, and used a hair dryer to melt the ice until it got loose and fell off. I plugged it back in, but noticed it is shutting off before reaching the desired temperature. I moved the thermostat from the usual 4 to 6...is this OK? It is essential that I maintain 39-42 degrees, as I use this for vaccines and they must be kept cold. I have a temperature gauge in there, but see that it is not reaching the desired temp before the unit shuts off. Will this unit reach the right temperature eventually, does it take some time to get cool again, or should I keep adjusting the knob until it reaches the temp and does not stop running until it does reach that temp? I would have thought that eventually it would maintain the right temp at number 4 again. I cannot have the vaccines freeze either...please give me your advice. I cannot locate the instructions unfortunatley. Thank you.
  • birdlover77 Jan 25, 2009
    Thank you for your prompt response. I did keep checking on it, and was able to gradually move the temp nob to 4 1/2, and it is keeping the temperature between 39-41 degrees, which is great. I do bird rescue work and also have a flock of my own, the vaccines are preventative medicine done yearly to keep the flock from picking up 2 common viruses...don't worry, they are not contagious to people or other animals. I love this refrigerator, it did well when we moved 3 years ago, 80 miles; it has plenty of room to also keep penicillan, vitamins and herbal remedies for my birds cold, and it is quiet, which is important, because birds tend to want peace and quiet once night falls. Thanks again!
    President:
  • Magic Chef Master
  • 2,651 Answers
OK as long as you used a hair drier, and not a screw driver to defrost this machine, you should be fine, it shoudl take no more then 24-36 hours to regain the correct temp, this being said, not real comfortable with the over the internet diag of a unit that potentially "keeps people alive"
Posted on Jan 25, 2009
Magic Chef RB15FA0AA Refrigerator I have this refrigerator and it still works fine. I would like to know it's total cu ft capacity. Also what the refrigerator and freezer each cu ft capacity is.
After some work online...I found this advertisement buried among a bunch of other ads:
Magic Chef RB15-1A: Top-freezer style with 14.6 cubic ft. capacity and optional ice maker -- $439.
So, as I suspected the "15" in the model number is the cubic feet (total I would say). The 14.5 is probably actual, with the unit "rated" as a 15 CF.
Naturally, to find the cu. ft of the freezer, measure in inches then multiply the width X height X depth and divide that resulting rather large number by 1728 to get your cubic feet of the freezer.
You could also do the same with the refrigerated section, and add the results together and they should be near 14.5 total.
Aug 03, 2015 | Magic Chef Refrigerators
Where can I find out where the drain hose is located on my Magic Chef refrigerator?
It should be under the fridge. If you remove the lower acess panel on the back you should see a little tray wich is your drain pan. Mike
Mar 19, 2013 | Magic Chef Refrigerators
I have an older refridgerator/modle #RB151PW, the freezer is not freezing and there is an ice build up inside the fresh food compartment.What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | Magic Chef Refrigerators
I have a Magic Chef Refrigerator Freezer Model MCBR1020W. It is a small 10 cubic capacity for my basement. It is about 18 months old. The freezer works great but the refrigerator compartment never gets to...
Is this a two door refrigerator?
If it is then their is an air duct that allows some air from the freezer to cool the fridge section.
Three things to look for;
Is the air duct blocked
Is the fan blowing air
is the freezer coil frozen over.
Try manually defrosting the fridge. If that helps then you have an auto defrost problem. A technician can help you there
Mar 31, 2011 | Magic Chef Refrigerators
Ice formation in Magic Chef Top Freezer Refrigerator
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | Magic Chef CTB1821AR Top Freezer...
Freezer ok but bottom refrigerator not getting cold,what should i do,lanlord not helping
Switch off for 12 hours and do a proper defrost. Looks like the evaporator fan motor is jambed due to an ice build up. retry.
Jun 05, 2010 | Magic Chef MCBR440 Compact Refrigerator
Magice Chef side by side builds up ice on freezer floor
it sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Jul 27, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef Side bye Side freezer started leaking
the drain line may be the problem. check to see if theres water in the bottom of the drain pan in the freezer compartment.
Mar 30, 2009 | Refrigerators
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
How many cubic feet (what size) is my fridge?
Need the cubic feet on our 16 year old Amana BX22A2W.
Jun 23, 2008 | Magic Chef CTF2125 Top Freezer...
Magic Chef MCBR170 Compact Refrigerator Logo
308 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
