Question about Roper RTW4300SQ Top Load Washer
Water Flow The hot water flow is very sluggish, water is just dribbling, the warm water flows fine, but is just luke warm, the cold water flow is normal.
  • achilders777 Jan 25, 2009
    I will try. Thank you very much for the answer.
    Could the waterheater be the issue? It makes really loud noises lately, but according to our apartment maintenance guy, this is normal in the winter..
    I live in CA, we had 80 degree weather last week,
    President:
  • Roper Master
  • 2,651 Answers
Disconnect your hoses and check for pressure without connected o machine, then check with int he water inlet valce for a clogged screeen slowing the pressure
Posted on Jan 25, 2009
  • Ron Coons
    Ron Coons Jan 25, 2009
    if the water heater had release some debris into the lines that s a possiblilty
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
I HAVE A SINGLE HANDLE HIGH NECK BLANKO KITCHEN FAUCET THAT IS RESTRICTING THE FLOW OF WATER WHEN TURNED IN THE HOT POSITION. THE WATER IS FLOWING FINE IN THE COLD POSITION BUT WHEN TURNED TO HOT...
If water come out the faucet hot line,check if is clogged.For this job you need to disassemble the faucet.
Here is a good PDF source to do it.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Blanco Classic Single Handle Faucet with...
Cold water dribbles in rinse cycle, hot and warm water fine
If you check the warm water flow you'll likely find it is HOT...and not warm. Check the faucet end of hose to see if screen is clogged. Should be screened washer with the dome portion of the screen facing out at you. Remove it and clean with brush to remove grit or scale from screen. If you find nothing there you need to replace the water fill valve located at the other end of the hoses. Good Luck
Aug 23, 2009 | Kenmore 22422 Top Load Washer
Water will not stay hot
The cold main water pressure is too low to maintain a constant flow. Make sure you have no other appliences on, or your not comprimised by the lowering of pressure
Jul 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Combi worcester 240. Plenty of hot water when heating running bot only luke warm when heating off. The pin in diverter valve working fine and ive tested the switch and that is ok !! Anybody got any ideas....
what u need to do is let the flow and return pipes for the heating go cold they are normally the 22mm ones and if 1 gets warm when u run your hot tap then u need a new diverter valve. if they stay cold then u need to see if the boiler is igniting in hot water so turn off the heating and just run the hot tap to see if it ignites get back to me
Jan 31, 2009 | Combi Centre DX - Mango
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
No cold water flow
TRY CHANGING THE COLD WATER TAP IN THE MACHINE.
Oct 13, 2008 | Washing Machines
Roper RTW4300SQ Top Load Washer Logo
168 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
