Acer aspire 4736g shut down unexpectedly
Hi there my laptop currently have some weird issues. my laptop shut down without bluescreen. It happened randomly. I dont think it should be overheating problem because i've just applied new thermal paste and keep an eye on the core temperature. The randomly shut down occurs more during starting up the laptop. It normally shuts down few time before i reach the logon screen. However, it stills shuts down when i'm in normal use like surfing the web, downloading, or even when i did nothing. windows event viewer log shows kernal-power, 41(63). besides, there's issue where my laptop cant power up using battery now. The battery still working when i start up using adapter and then take off the adapter. I'm not sure whether this two issues are related.
    Genius:
  • 1,250 Answers
Try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Posted on Jan 17, 2013
5 Suggested Answers
  • 66 Answers
SOURCE: Acer Aspire 5630 Laptop Unexpectedly Shuts Down
r u allowing the fan to intake air to cool down cooldown
Posted on Apr 28, 2010
GSPOT12
  • 75 Answers
SOURCE: My acer aspire 5742z laptop
Hi!
Issues like this mostly caused by a program or simply a corrupted operating system updates. I would suggest we try restoring the laptop back in time when the issue is not yet present. We can achieve this by performing System Restore, if I'm not mistaken, this laptop has Windows 7. Please click on the Start button, then go to All Programs> Accessories> System Tools and then finally System Restore. Please select a date when the issue is not yet present. Then, please reboot the laptop.
Hope this helps.
Posted on Apr 17, 2011
davidmamian
  • 543 Answers
SOURCE: Sony Vaio has started shutting down unexpectedly.
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Posted on Jun 11, 2011
willem52
  • 359 Answers
SOURCE: My Acer Aspire 5517 keeps shutting off...
1. Check if the air duct inlet and outlet are free and free of dust.
2. If needed, clean it with a hard brush and vacuum cleaner.
3. Check if the fan is rotating, if not replace the fan unit.
4. Check if the fan is clean of dust, if so clean it.
Posted on Nov 16, 2011
Samsung Laptop Shuts Down Unexpectedly
It may be overheating. Try using a vacuum cleaner hose on the air vents, that will help to clear the ventilation for the radiator.
Jan 18, 2014 | Samsung Computers & Internet
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
Unexpected shutdown with my acer laptop
if it keeps shutting down/ CRASHING and then it goes to a blue screen leave it for about 30 mins and if it does it again get your RAM upgraded from whatever GB it currently is to about 4, 5 or 6 GB!!
Aug 05, 2013 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
My computer screen turns blue and restarts window vista
Hi jjlishus,
I see you mentioned that you are having issues with you computer going into a blue screen then it restarts.
You can try to boot into safe mode to see if Windows Vista will Load without having the bluescreen and if it will not shut down or restart, from Safe Mode, try and do a system restore to a data where the problem has not happened yet.
From there-on see if the issue will still happen or no
Getting into Safemode:
restart PC keep on tapping F8 on your Keyboard this will prompt you options, Look for Safemode then press enter this should bring up the safemode screen.
If during the loading of safemode and still happens are any error show up or it goes to a blue screen, you can try going into safemode with command prompt.
to get to safemode in command prompt just do the same as ging into safemode and select safemode in command prompt.
once in the command prompt
Type CHKDSK , then press enter it should check the system for 5 mins or so depending on your PC/Laptops speed.
if still the issue is the same reformatting or restoring your windows back to defaults may fix the issue.
I hope that this will help,
mvincentc
Jun 07, 2012 | Acer Brand 14.1 WXGA Matte Laptop...
Acer Notebook 5315 overheats and shuts down unexpectedly
The weak point of ACER is overheating. I always plug in on usb port additional fan and place it right below the ACER to prevent overheating.
Regards, vote please, Jay
Jan 25, 2011 | Acer Aspire 5315 Notebook
Apr 28, 2010 | Acer Aspire 5630 Notebook
My acer aspire 3680 shuts down unexpectedly only when the battery is plugged in. When I remove the battery it works fine. Is the problem with the battery or something else in my computer?
It is the battery. It is damaged, and because of that it changes the voltage of the AC. the best solution is to replace it with a new one, but until then, work without it, or you might have fried lap top
Nov 14, 2009 | Acer Aspire 3680 Laptop
Acer Travelmate 4650 cuts off unexpectedly????
add a desktop fan next to ur pc this will cool ur pc down ....if problem still happened call ACER costumer help
Mar 07, 2009 | Acer Aspire 5610 laptop vista combo with...
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
