Question about Vizio VO37LHDTV10A 37 in. LCD TV
VO37L HDTV10A backlight on, get sound, no picture
TV was given to me by grandfather after it had suffered issue from lightning strike. Originally, TV would not turn on. I replaced Main board and Power board and got the device to turn on. Now, in its current state, TV turns on, I see the backlight of the TV turn on, and I am able to hook up HDMI from my laptop to the TV and play a video. I can get sound just fine, however no picture is displayed of the video. So it seems the last piece to the puzzle is what would stop the actual picture of the video from being displayed on the screen? Is it the backlight inverter board? I've hesitated to order that part, because I am under the impression that that particular component only affects the backlight coming on. Am I incorrect? Is there anything else I could be testing? The voltages from Power board to backlight inverter seem to give okay readings.
  • Vizio Master
  • 933 Answers
TV sets that have been exposed to significant surges can have multiple boards that are damaged. If the backlights are indeed firing, and you get no picture, you may have a problem with the T-Con board, assuming the main board is working properly. This is exactly why I steer people away from repairing sets that have been hit with large surges. In most cases it will be cheaper to buy new sets vs. repair them.
Posted on Jan 17, 2013
  • 2318 Answers
SOURCE: Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Posted on Dec 15, 2008
info33
  • 72 Answers
SOURCE: Vizio VO37L LCD will not display picture. Screen
Here is teh quick start guide from Vizio - make sure your set up is correct and the inputs are in the right place. Follow this -
http://www.wigix.com/index.php/skuaccessories/downloadManual/2166516/10708/0/Vizio-LCD-Flat-Panel-TV---37-VO37LFHDTV10A-Quick-Start-Guide.pdf
Posted on Jul 03, 2010
budmrtn
  • 11361 Answers
SOURCE: Vizio SV470XVT1A has no backlight
The 24vdc is turn on by the signal from the main logic board, it is not always on, the standby 5vdc is always on. So yes it can be the power supply board is bad, but just to besure we need to find out if it is getting the turn on signal from the main board first.
You can have 24vdc at the inverter board and it will not light up the CCFL until it gets the signal from the main logic board to turn the lamps on (this is the STANDBY condition, the TV is on but the screen in not lit up util it see the video signal).
Send me good clean and clear pictures of the power supply board, budmrtn@aol.com, connectors of the Power supply, bottom side of the board, then I may be able to tell you which pin is a control input pin. Most people will just throwing parts in and hope that they one of the parts will fix the problem. Used Power supply module for this TV is over $100. http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=delta+DPS-379AP&um=1&ie=UTF-8&ei=USsxTKn3J6TonQfFlJGEBA&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCsQrQQwAw
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+SV470XVT+
Posted on Jul 05, 2010
Testimonial: "Bud helped me fix my TV! It was only 1 1/2 years old. I was looking at a repair bill close to $300 - $500 and I fixed it with a $60 board! Thanks!!!"
TV #1
  • 129 Answers
SOURCE: my 32" lcd vizio vx32L turns on there's sound
Have you tried the T-con board?
Thank you,
Posted on Dec 18, 2010
  • 12 Answers
SOURCE: I have a vizio vz37l tv. When i turn it on the
its the main board...
Posted on Mar 07, 2011
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
TV out after lightning strike. TV led light comes on for 5-10 seconds then shuts off. Phillips 46pfl3505d/f7. Can this be fixed?
Sure it can be fixed. Most likely a problem with the power supply being zapped by the lightning.
Check to see what the price of a new PS is and is cost effective given the age of the set.
Jan 03, 2017 | Televison & Video
No picture or sound after lightning strike. tv was not connected to syrge protector.
I had the same problem. If you open it up and locate the power supply you will see two 8A 250v fast acting fuses. One or both may have blown. Replace them and see what happens. Cost about $3. Good luck
Aug 08, 2012 | Sanyo DP50747 50 in. Plasma TV
Vizio VW42L HDTV10A, Black screen name display on no sound nothing,VIZIO tech says suapects backlight bulbs, but why wouldn
If the backlights lamps are bad, you will not get picture but will still have sound. Lamps (est. life of 50k hours) are rarely goes out, its electronics that go out first. I do not think the person you talk too ever work on the LCD TV.
More liekly that the 12v (for sound) and the 24vdc (for backlights) power supply section is not working.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 22, 2011 | Televison & Video
Lightning strike, blows internal fuse (6.3v 125/250) on plug in.
sounds like the lightning strike took out at least the power supply if not more. sorry to be bearer of bad news.
Oct 31, 2010 | Toshiba 24AF41 24" TV
27r410t no power
did you check that you are receiving a good hot (a consistent 110 ac) check the tv on a different outlet otherwise the chassis board has malfunctioned inside the tv. Probaly the flyback transformer which converts the 110 ac to thousands of volts to power the CRT (picture tube) which has failed more than likely. Usually the culprit after sustaining a surge from a lightning strike. Not worth the repair just replace go to your local pawn shop for a great deal on another used tv
Aug 15, 2009 | RCA F27664 27" TV
Lightning strike and tv picture messed up
This unit needs to be sent or taken in to a service center for complete testing and service. The lightning strike has caused a component failure, in the main board of the television. This is the board that controls all the functions of the television. The customer service telephone number for Insignia is 1-877-467-4289. You can also go to the website www.insignia-products.com. Go to the customer support section and ask them for help getting you television evaluated and serviced. I hope this information helps you solve your problem.
May 18, 2009 | Insignia 37" LCD Flat-Panel HDTV
Hitachi Rear Projection
Hi! Guy,
I don't think your problem was caused by lightning. It sound like defective convergence ICs. This must be checked and verified by a qualified service tech.
Toprol
Oct 11, 2007 | Philips 60P8342 60" Rear Projection...
Vizio VO37LHDTV10A 37 in. LCD TV Logo
230 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
