Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
No water pressure for ice maker or water despenser
The channel feeding the ice maker tray will freeze up solid with water because it has no pressure. will thaw out and clean channel and line feeding ice maker but will freeze up in couple of days. water despenser has no pressure. it will dribble a little water out and then air then some water. changed filter after started having problems and has good hot water preesure feeding fridge
  • 1 more comment
  • Anonymous Jun 04, 2008
    My icemaker just do not make ice, neither water comes down like I use to hear it. I have not done anything but lift the lever on and off.
  • Anonymous Mar 19, 2014
    WILL NOT MAKE ICE
  • Anonymous Mar 29, 2014
    will not despense water but will despense ice
Hi,we had this sort of problem on and off for a while then called in homecare (it was insured for breakdown.)they removed the top salad draw,took off the cover that sits behind the draw....replaced a part in there..which he said regulated the water...or temp I'm not sure..he said it was a common fault...but it cured our problem completely..no trouble at all now....hope this helps you.....Su...West Mids..12-7-07..
Posted on Jul 12, 2007
    Novelist:
  • 159 Answers
Sounds to me that you attached a bulet piercing valve to a cold water pipe. If you did I would say the tiny hole that the valve put into the pipe has blocked up and causing your low water pressure. I have sen this problem a million times with that type of valve. You could try to close the valve and then open it back up. Sometimes this will clear the hole. If not I would replace the valve with the type of valve you have for your sink. there better in every way. You may need to have a plumber do the job for you but you will never have this problem again. Good luck
My ice maker isn't despensing enough ice fast enough to fill the ice bucket up
Ice makers spray cold water upward into cube shaped trays that freeze the water almost instantly upon contact . Then when you press the ice dispenser a heater comes on that releases the ice cubes from the metal trays. If it is very old replacement probably a good option.
Nov 27, 2017 | Refrigerators
Leaking water from my refrigerator
Tubing in back of refrigerator leading to the ice tray is jammed with solid ice and whence maker timer calls for water back pressure prevents water from reaching the ice maker tray. Remove the tubing from the back and pull out the plastic tube that feeds the ice maker tray. Put the tube in hot water to melt the the and blow through it to make sure itis clear. When reinserting the plastic tube stick your head inside the freezer door and be sure the end of the tube overlaps the tray. The problem will be solved but the same thing will happen at some later date. I believe I solved this problem too. I got a roll of surgical adhesive bandage that's about a sixteenth inch thick and insulated the tube to prevent it from freezing again. It's been two months since and thank God it worked. The Frigidaire engineers could use this one.
Mar 01, 2015 | Frigidaire Professional Series PHS68EJSB...
Why does my ge pss26lg side by side despense water but no ice?
Just because you get water from the dispenser does not mean you should also get ice made in the ice maker. Fact is there are two side to the water control valve. One for the ice maker and the other for the water dispenser. Is there ice remaining inside the ice maker slots? If not then pour water into the tray until full and if after the water freezes it drops the ice into the ice bin this will indicate a defective=> WR57X10032 Water Inlet Valve If nothing happens and the ice maker tray are full of ice this will indicate a defective=> WR30X10093 Ice Maker Assembly The ice maker is cannot be rebuilt on this model. I am here if you have questions, Thank You, John T Appliance 911
May 07, 2014 | GE Refrigerators
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Ice maker will not despense when full of ice
Hello , that is exactly what is happening this is caused by 1 of 2 things.
1- the module/control on the front of your ice maker is sticking during its cycle and over timing the fill stage.
2-your inlet valve located in lower rear at water line connection is not sealing causing water to seep through line to ice tray and overfill.
Both are common issues and the most cost efficient way to repair this is to order the ice maker kit that contains both the ice maker and the valve so you can guarantee the fix.
You can purchase on line with your model number for around $100 Calling a service company will cost at least $150 changing only one of these parts or about $200+ for both.
If you have any questions please ask and let me know how it goes.
Phil
Jan 02, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Ice Maker
ice Freezs in storage tray
Apr 19, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Side by side fridge / freezer - Icemaker problems
What kind of ice maker do you have? Is it "Ice Maker Plus"? Pull the ice bucket out so you can get a better view. On the back of the freezer is a spout ramp that should connect to the back of the ice tray water deflector that the wire connects to. (I know, It's cold in there). The water deflector is connected to the back of the ice tray which sends the water to the tray. It should snap in.
Jul 06, 2007 | Whirlpool ED2FHSS Side by Side...
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
664 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
