Question about Dell Vostro 230 Slim Tower PC Desktop
What are the components that you need to remove before removing/replacing the power supply on a Vostro 230 slim tower
3 Suggested Answers
SOURCE: My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Posted on Dec 15, 2009
joecoolvette
  • 5660 Answers
SOURCE: My vostro 230 slim tower will not power on. I have replaced the power supply
Did you perform the test to see if the problem was the Power Supply, or Power On switch, F-i-r-s-t?
The Power On switch is bypassed, but has nothing physically to do with the switch.
A jumper wire is used to temporarily connect the Soft Power On wire, (PS_ON) to ANY Ground wire.
IF the Vostro power supply comes on, you have a bad Power On switch.
IF the Vostro power supply does Not come on, you have a bad power supply.
Also; Power Supply is new? Doesn't mean it's good.
Not directly indicating that you have a bad Power Supply. I think it's a $5 ATX power on switch,
http://www.directron.com/atxswitch.html
With the above test however, you will know.
The Soft Power On wire is in the 24-pin ATX main power cable. It is Green in color.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Note* Color of connectors does NOT matter )
View the photo to the far right. See the Green wire going into the BACK of the connector?
This is the Soft Power On wire.
Observe the photo in the middle. Note you are seeing the Front of the connector. The wires go into the Back of the connector.
For each wire going into the Back of the connector, it ends in a metal female terminal, at the Front of the connector.
Resembles this,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
(The connector has square socket holes. This makes the rounded end of the Molex female terminal end, look square)
The 24-pin ATX main power cable is plugged into the motherboard, as shown in the photo to the far right, and the computer is plugged into power.
The jumper wire is inserted down into the BACK of the connector, RIGHT NEXT TO THE EXISTING wire that is already there.
Slides down into the socket hole of the back of the connector, right next to the Green wire, and then touches the female metal terminal end.
It has to slide down into the socket hole far enough, to ensure that it touches the metal terminal end.
A paper clip is preferred for the jumper wire.
The paper clip is straightened out, then bent into a U-shape.
The middle of the U, is wrapped a few times with black plastic electrical tape.
This area is for your fingers to hold onto.
The 'legs' of the U go down into the socket holes.
One 'leg' down into the socket hole with the Green wire.
The other leg goes down into ANY socket hole, with a Black wire in it.
ALL Black wires are Ground wires.
The contact made is no more than 2 seconds.
(The ATX power on switch is a Momentary Contact Switch)
There may be a spark. Warning you in advance.
However you are only dealing with 5 Volts DC.
In comparison two D cell flashlight batteries store 3 Volts DC.
[ You push the Power On button. The plastic Power On button in turn presses against an ATX power on switch.
When a Power Supply (Computer) is plugged into power, there is a constant 5 Volts (DC) standby power present.
With the Power On switch being closed temporarily, 5 volt power is re-routed through the Power Supply.
This 5 Volt standby power 'excites' the Power Supply, and turns it on.
{ To go further;
The first chipset on the motherboard to receive power is the BIOS chipset.
The Basic Input/Output System (BIOS) is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
Windows XP and Windows 7 are two examples of an O/S.
Operating System ]
To replace the Power On switch;
The ATX power on switch is located inside the plastic Power On button assembly.
After time of constant heat inside the computer, and age, the plastic starts to harden.
This can make the plastic brittle, and want to break, when you try to remove the ATX power on switch.
There are two methods you can use to soften the plastic, and try to keep it from cracking, or breaking;
1) Front Panel removed, Power On button assembly removed;
Use a hair dryer set on low to soften the plastic.
Constantly move the hair dryer around.
2) Front panel removed, Power On button assembly removed;
Use a bowl of the warmest water that you can stand.
The old Power On switch is going to be thrown away anyway, so it doesn't matter if it gets wet.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Mar 14, 2012
Need to upgraded power supply
If the power supply has the correct size format and has all the correct connectors there would be no reason you could not upgrade. However some vendors use unique power supplies on the small form factor pc's, but you should be able to eyeball and tell.
Aug 09, 2015 | Dell Vostro 260s Slim Tower 1 X Core I5...
I am getting an amber light on my Dell Vostro 230 desktop and it won't boot up
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Sep 17, 2013 | Dell Vostro 230 PC Desktop
I am getting an amber light on my dell vostro 230 pc desktop
check if u have a RAM problem and if the powersupply is failing
I have a dell vostro 230 slim and I can not get a picture from the on board video what can I do. And if I get a pci-e low profile video card will I half to change the bios for it to see it?
If you are sure the graphics adapter is gone, you have check ALL cables, connections, try another monitor/ cable, drivers: http://www.dell.com/support/drivers/us/en/04/Product/vostro-230. A Graphics card is a option, make sure to look at the min. requirements for the graphic card, the power specs are important. I would not change the BIOS if Dell does not require it.
Jan 06, 2013 | Dell Vostro 230 PC Desktop
DELL VOSTRO 230 PROBLEM
Your computer is toast! If it was submerged in water, your motherboard, hard drive, memory and power supply are contaminated.
Jul 03, 2012 | Dell Vostro 230 PC Desktop
Vostro 230 - Solid Amber Power Light
"power supply seems to be working?" If you had before this happened a issue where had to turn it on a few times to get it up---suspect bad caps in power supply---A look inside that will tell you if this is the issue or not. If the supply can be removed (most can) it can be examined or tested by most repair shops for little or nothing.
see attached photos of what bad caps look like in case you remove the supply to look at it.
Jun 15, 2012 | Dell Vostro 320 Desktop Computer
Dell Studio slim that will not turn on. Light on back is green, but power button will not work
First place to look is the power supply in the tower---most likely if just before it failed you had to turn it on a few times to get it on---bad filter caps in the supply.
The supply usually can be removed and most shops will test it for little or nothing.
If you are able to get at it and get it out look for bad filter caps like these:
good on left and bad on right
Arrows point to really bad caps--tops have to be perfectly flat.
Jun 10, 2012 | Dell Studio Slim-Tower Desktop Computer
The RAM modules may need reseating. After reseating and your computer still does not boot up then the RAM maybe faulty. Remove the RAM modules and take them to your friendlt computer shop and get them to test the RAM.
Mar 13, 2012 | Dell Vostro 230 Slim Tower PC Desktop
How do I get to the motherboard? I need to replace
This for the Mini Tower version
This is the slim tower version.
On the board you will look for a coin cell battery, like those you use on watches, key chain remotes, and cameras. They look like money change; the size of a quarter. There will be a metal latch that you depress and the battery should prop up.
Replace battery in the same way you found it,
PLEASE POWER DOWN PC AND REMOVE ALL POWER CORDS, VIDEO, KEYBOARD, MOUSE,USB DEVICES ATTACHED TO COMPUTER PRIOR TO THIS PROCEDURE.
ENSURE THAT YOU ARE GROUNDED. IF YOU DO NOT HAVE AN ESD MAT OR ESD GROUND WRIST, YOU CAN avoid static discharge damage YOURSELF BY STAYING OFF OF CARPETS OR RUGS.
Jun 01, 2011 | Dell Vostro 200 (CU409) Motherboard
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
Dell Vostro 230 Slim Tower PC Desktop Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
