Question about Panasonic NN-T990SA Microwave Oven
Panasonic Inverter Microwave 1250 watt Oven model NN-S935BF
I set the time it runs for a couple of seconds and shuts off. A strange "burnt plastic" odor can be detected. especially from the rear vent.
  • NASCARLANCE Apr 05, 2009
    Same here runs for 4 seconds and quits. From what I have found it is most likely the inverter and it seems to be a common problem with these Panasonic microwaves.
MicrowaveSvc
  • 9086 Answers
SOURCE: scrape or fix? Panasonic inverter genius sensor 1250 watt
In most cases, this is a problem with the inverter but it may be a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
  • 579 Answers
SOURCE: PANASONIC NN-S933BF 1300 WATT INVERTER
yes, get that fixed. it is a danger.
Posted on Jan 01, 2008
EwingElect
  • 276 Answers
SOURCE: Shuts off after 23 seconds....
In most cases when the microwave stops @ 23 seconds it's the Magnetron which has failed, and is shorting to earth.
Either that or the magnetron isn't getting the right signal from the inverter board. It gives it 20 seconds to get the right signal or it shuts itself off.
Posted on Apr 04, 2009
  • 4090 Answers
SOURCE: Panasonic Microwave NN-S935BF turntable and light
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
No power to light or turntable
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Posted on Aug 16, 2009
SOURCE: Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Posted on Nov 24, 2010
Panasonic Microwave will not work pass 20 seconds
Your Unit has an inverter, when the unit stops running after 10-20 seconds it is having a problem with either the Magnetron or the inverter. Sometimes both. There is not an easy way to test the inverter, the mag can be tested for shortage to ground with an ohm meter and between the terminals to check the filament for continuity. But if both are bad it is cheaper to buy a new unit.
Oct 26, 2017 | Panasonic Microwave Ovens
Microwave will not operate unless I slam the door shut then program to cook.
of course it is , most likely needs a new door switch .
Oct 21, 2015 | Microwave Ovens
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Apr 04, 2009 | Panasonic Microwave Ovens
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
You can find an authorized Panasonic servicer here.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Shutting Off Prematurely
may be highvoltage circuit or high voltage diodes, or mains power problem, check the control unit.may be magnetron..
Sep 25, 2007 | Panasonic NN-S634 1250 Watts Microwave...
Panasonic NN-T990SA Microwave Oven Logo
153 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
