Question about Dell Inspiron 1501 Notebook
Keyboard malfunction? Recently when I started playing certain games and trying to enter in codes, I found that they did not work. I initially dismissed this as normal for those games, as some will malfunction with too many codes. However, when trying to redefine controls for the same games plus others, the system somehow interprets a signal from the # key (or the = key for some games) without me pressing either of those keys. The problem seems to be system-wide, as my screensavers will not activate in "preview" mode for more than a second. However, word processors do not have this problem and function normally without showing # or = on any keystroke apart from keystrokes I deliberately input. I am particularly perplexed by the # key signal as I am not pressing the Shift button, ergo this should be impossible. I am using Windows Vista Business and the problem has only occurred in the last month or so. I cannot detect any physical fault with the keyboard.
  • 1 more comment
  • Anonymous Jan 25, 2009
    The tests all passed. Neither = nor shift+3 (#) showed any signs of malfunction.
  • darkfighter3 Jan 25, 2009
    The tests all passed. Neither = nor shift+3 (#) showed any signs of malfunction, and the problem still occurs.
    The problem is still there on a new user account. It is exactly the same (ie. it is neither better nor worse than my regular account).
  • Dell Master
  • 1,183 Answers
HI,
Run a quick diagnostics on the keyboard . To check if the keyboard is OK .
To do the same
1. Shut down your computer
2. Hold down the Fn key and press the power button
3. PSA diagnostics screen would appear , which would test the LCD and you would hear beeps
4. Second a memory test would run
5. It would prompt you to run advanced memory diags , say no to the same
6. Enter the dell 32 bit diagnostics on the next prompt
7. Run a custom test on the keyboard.
Do post the results .
Thanks
Proton
Posted on Jan 25, 2009
  • Mandeep  Singh
    Mandeep Singh Jan 25, 2009
    If the test have passed , then the problem is with the software part of the computer.
    The best option would be to create a new user account in windows and check , if the problem gets resolved
    Thanks
    proton
I have download sonic R for pc when I Start my game it starts but my keyboard doesnt works please help me !!!! THANKS
The Problem Is you wont get the keyboard working unless you have a 2004 copy (i found that souloution on yahoo answers) so if you get that you can play the game perfectly! =P
Jan 13, 2013 | Sega Sonic R for Windows
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
How do I delete items from recently found? How do
When you want to add a place to your favourites
  • Press WHERE TO
  • Enter the address
  • Instead of pressing GO press SAVE at the bottom of the screen or press VIEW MAP and then SAVE
It will be saved to your favourites folder and the keyboard will come up for you to give it a name.
You don't delete items from recently found. A certain number of items are kept there and overwritten as new ones replace older ones.
Jun 17, 2011 | Garmin nuvi 255W GPS Receiver
My ps3 freezes while playing certain games..i.e. God of War3 and Assassins Creed..What's the problem?
try updating firmware or doing hard reset.
this is a last resort Sony support recommends.
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
-freezing when doing anything
-no harddrive activity
-freezing when trying to use onboard keyboard or bringing up keyboard
-game/movie disc freezes system
Apr 09, 2010 | Sony PlayStation 3 Slim Black Console
My new laptops keyboard doesnt work with some games
Configure the game's controls to your choice.
Jan 01, 2010 | Computers & Internet
After playing game 2 hrs mechine bcom slow & does't work.I use nVidia-6200 gt graphics agp card& AMD 64,3000+ processor wth 1 gb DDR.Keyboard doesn't work & shows keyboard harware not found.Pls...
After 2 hours of game playing I suspect you need to come out of the game and reboot to regain system resources. Make sure any uneccessary programmes are not running in the background eg virus checkers, updaters etc, and I would certainly recommend at least 2gb ram.
Get a new keyboard preferably a USB version if you have a PS2 k/board.
Best of luck.
Please feel free to rate this suggestion if you feel it has helped. Thanks.
Oct 09, 2009 | ASUS K8V-MX Motherboard
Keyboard gaming malfunction
I had the same kind of problem with my Merc Zboard gaming Keyboard. I had to uninstall the software for the board. I then went to the manufacture's website and downloaded the updated drivers directly from them. This fixed my gaming issues 100% ^_^
Sep 11, 2009 | ACCO Brands Kensington Ci70 Wired Keyboard...
Honda Civc 2004 radio code entered plays for 30 seconds and quits?
Not sure? If it is the wrong code it shouldn't work at all? Try leaving the radio on for an hour without doing anything and then re-enter the code. If that doesn't work, contact your nearest Honda dealer.
Sep 06, 2008 | 2004 Honda Civic
Call of Duty 4 no longer works
Take it back. I have had the same problem with my 40gig and many others are too. Sony has been having problems with the drives
Mar 24, 2008 | Sony Playstation 3 (PS3) Console
Dell Inspiron 1501 Notebook Logo
224 people viewed this question
Alun Cox
