Question about Lowrance LGC-2000 GPS Unit GPS Receiver
Power to Lowrance GPS
When I connect my GPS unit to the LGC-2000 bus with the blue connector cable, Do I need to all so connect the power cable from the GPS unit, Or will the bus power power the unit?
Thanks,
Yes you have to hook up the red wires together to the + and both black ones to the negative, otherwise the antenna won't be supply in current , and don't forget to insert behind the red wire a fuse and a switch to avoid to discharge your battery .
Bernard.
Posted on Apr 26, 2009
My Lowrance unit gives me a message of
Hi check the receiver has 12 volts at the blue plug, if so the mushroom is most likely fried, regards Phil.
Jun 10, 2012 | Lowrance LGC-12S GPS Receiver GPS Receiver
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
The GPS claims that the transponder is not communicating. All cabling looks fine and there is no apparent damage to the head.
Normally this error shows that something is wrong with the antenna itself. If the unit is old it's best to change it out. most gps antennas are only good for about 5-10 years. unless you have had a lightning strike close by then less. The other thing is to make sure that you don't have the internal gps selected in the menu and that you have both terminators on the nmea 2000 network that the LGC-2000 is connected to.
Oct 29, 2009 | Lowrance LGC-2000 GPS Unit GPS Receiver
Every time i turn on my lowrance 520c it says gps module not resp
I had the same problem. Sent my entire unit back to Lowrance, but they said it was fine. One year later, I find out that I did not receive or have the correct parts to hook up the GPS unit. I needed the NMEA 2000 T connector and terminator plugs. Look at your manual and hook it up the way the manual says. It will require a NMEA 2000 T and at least one 60 ohm terminator plug. Seems the GPS module sends back some kind of signal that if not absorbed by this thing will mess up your unit. Mine works since I got it hooked up correctly. HD
Jul 17, 2009 | Lowrance LGC-3000 GPS ANTENNA FOR UNITS...
Lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
Where to put gps receiver, for fish finder, lowrance m52 s/gps
The receiver needs to be mounted so that it has a clear, unobstructed view of the sky. It will be fine through glass windshields, fiberglass and cloth tops. Keep it at least 2 feet away from the display unit.
Jun 30, 2009 | Lowrance LGC-2000 GPS Unit GPS Receiver
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
I just bought a lgc 2000 antenna for my lcx 20 lowrance. i haven't any manual but the seller said all i had to do was plug it in. well, all i get is" gps module not responding".is there something...
hi the lgc has to be powered also with the nmea cable,red to+,black and shield to-,you also need a 60ohm terminator atached to the short length coming from the y piece,the manual does not state this very clear and lowrance is not much help
Apr 28, 2008 | Lowrance GPS
Gps module
I just went through this with Lowrance. tthe LGC 2000 module on my LCX 20 depth finder "quit responding" out of the clear blue. You have to go Lowrance.com and they have some tests you can follow to see if it is a bad cable or the module itself. I had to replace the module. They charged $99 bucks plus $12.50 shipping for a new one. I bought it spring of 2008, and the unit was 3 months out of warranty when it quit working. Last season I had lower back fusion and didn't use it except for 2 times late in the season. Getting ahold of Lowrance is going to be an experience. I called twice and waited on hold over 35 minutes before I was suddenly cut off both times. I tried email too, but it took 3-5 days to receive a response. Mine broke down June 18 of this year. I started trying to get hold of Lowrance the next day. By the time all the back and forth emails with the delayed responses were done, I received my new unit on July 24. 5 weeks! with out my gps in MN. It is a short season up here as it is. I sure didn't enjoy waiting that long.
Oct 19, 2007 | Lowrance LGC-2000 GPS Unit GPS Receiver
Lowrance LGC-2000 GPS Unit GPS Receiver Logo
638 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
