Question about Dell Inspiron 8600 Notebook
Need External Monitor to Work
I have a Dell 8600 laptop windows XP. My monitor doesn't display properly (at all). I want to use an external monitor instead. Is there a function keyy to make it start with the external monitor instead?
  • olbilly Mar 05, 2009
    My LCD works only for a few minutes then goes black. I have hooked the computer to a CRT which works. Is it worth the cost to have the LCD repaired?
  • Anonymous Mar 17, 2014
    It lights up but instead of a display I just get a bunch of vertical lines. I connected to an external monitor and works fine. Any ideas on where to start my repair?
  • 3,940 Answers
The Fn +F8 combo will toggle between 3 options,
LCD
LCD and EXTERNAL
EXTERNAL only
Posted on Jan 25, 2009
  • 98 Answers
Have a look at your bios settings you can disable the laptop screen in favor for the external display
Need both laptop and monitor on at same time.
Hey Roger,
Below is information that should help you with trying to get monitor and notebook screen to work.
First make sure your laptop is equipped to be able to connect a secondary display, there should be a port for connecting a standard monitor cable on the back.
Connect your secondary monitor and reboot the laptop, the system bios should recognize that a second monitor has been added.
Then right click on your desktop and bring up the display properties dialog box.
Select "settings"
Your laptop should be identified as monitor 1 and you should also be able to see the secondary monitor as monitor 2.
Click on the secondary monitor and check the box that says "Extend my Windows desktop onto this monitor".
Set your screen resolution and color quality for the second monitor and click apply.
Directing icons and browser windows over to the other monitor is just a matter of drag and drop.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 11, 2014 | Dell Latitude D600 Notebook
Tip
External monitor out of range error on Dell Latitude E-Series portable
If you have trouble getting a display on an external monitor, the issue can be resolved by making the proper settings in the Video Driver Control Panel applet, instead of the Windows Display Properties.
The issue occurs when the display settings for the external monitor are set higher in the NVidia Control Panel than the monitor could display. The settings overrode any Windows Display Properties setting. Similar issues have been seen with the Intel GMA Graphics Controller.
These issue occur docked or undocked with a variety of external displays, projectors and TVs.
So remember that the NVidia and Intel Control Panel settings override the Windows Display Settings.
on Mar 25, 2010 | Computers & Internet
Dell XPS 140 monitor is blank, however the secondary monitor attached displays floating Windows XP. How can I transfer the primary monitor across to the secondary monitory to be able to use the compu
this is from the manual for your computer. you need to get it on both monitors simultaneously.
When you start the computer with an external device (such as an external monitor or projector)
attached and turned on, the image may appear on either the computer display or the external
device.
Press <Fn><F8> to switch the video image between the display only, the external device only,
or the display and the external device simultaneously.
Jul 12, 2012 | Dell Inspiron XPS M140 Notebook
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
Hooking 2 monitors to laptop?
Only way is to replace your lcd screen if you dont want to spend on a external video card,heres a parts break down of your machine ,
http://supportapj.dell.com/support/edocs/systems/ins8500/en/8500/sm/system.htm#999507
Cheers Misterdj
Honestly buy the external card or a second 8600 and transplant the lcd
Please rate me thanks
Aug 12, 2009 | Dell Inspiron 8600 / Latitude D800 /...
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Black LCD Monitor Dell Inspiron 8600
Since the external monitor displays and dim image on the laptop's LCD screen then the fault is the LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 04, 2009 | Dell E228WFP LCD Monitor
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
My AL1716 doesn not work in DOS
Hi
The screen probably does work in DOS but the laptop doesn't bother sending it any signal in DOS, it's only when windows starts that windows takes control of the displays and shoots out a signal to the external monitor
I don't know how you would get round this because you can't see your BIOS which you need to go in to and set the primary monitor to external.
Feb 06, 2008 | Acer AL1716 17" LCD Monitor
Dell Inspiron 8600 Notebook Logo
489 people viewed this question
Alun Cox
