Question about LG LB8000ER Air Conditioner
Air Unit turns on...compressor works, fan turns on and then shuts off?
I just got this brand new air conditioner. I turned it on, placed the temp on 60. It seemed to start up (compressor was working) but there was no air coming out and then the unit stopped. It would come back on for a minute and then turn back off. HELP!!
    Scholar:
  • 36 Answers
Let me guess you drove it home on its side in your back seat and then plugged it in? Or like many stores with a surplus of product and limited space, there are some units that are stored on their sides by idiot employees, or ones that don't care they just want to get the freight put away. All of which will more than likely result in a dead air conditioner, refrigerator, or dehumidifier if the unit is not upright overnight before use. The refrigerant is also acts as the lube for internal parts and when stored improperly will all be located in the coils, and not in the compressor where it needs to be. You plug it in and the unit will overheat and die. Either that killed it or it was DOA, go back and exchange it. Why bother troubleshooting something you can exchange? If you did drive it home on its side don't tell them that, unless you are that guy who didn't put 50:1 in his lawn mower. Hack
Posted on Jul 12, 2007
  • LG Master
  • 8,220 Answers
Half of them acs come out the box distressed. LG stands for Lot of Grief. Get a refund and buy american texas made stuff like fedders or freidrich. Stop puchasing that worthless **** nobody has parts for.
What you need to do before you buy a product is see who fixes it how much it will cost and are parts available? These crappy units are fresh off of a container ship from a country that has no manufacturing standards whatsoever and does not intend to get any.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 21, 2009
Error 3 luxaire heatpump
It's the compressor it's not comming on check the capassator in the outside unit it's 60 far rot it popped course the motor was struggling to start if the compressor it empty it burn out the cap
Aug 26, 2016 | Heating & Cooling
It seems like only fan is working no air. The switch is on cool and the temp at 60
Turn the temp all the way up and wait a munite then trun it down and listen for the compressor to come on. If it does not then it could well be the contactors. . Bad tstat, or the compressor gave up the ghost. also try unplugging and plugging it back in remember wait an minute or 2 before you plug it back in
Jul 19, 2011 | Kenmore 75050 Wall/Window Air Conditioner
I have a brand new york inverter air conditioner that does not want to cool!
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Dec 29, 2010 | Heating & Cooling
My frigidaire air conditioner model FAA060p7a will not cool the fan works fine but on cool the compressor does not kick on, if I turn the the temp knob you can hear it click behind the knob like its...
The problem here is the compressor.... it has failed and will not start. You can try to replace the capacitor and see if it will go but most likely the compressor is toast. I t will cost more to replace it then to buy a new unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Frigidaire FAA060P7A Air Conditioner
Fan works but compressor does not start. Its a brand new unit
Hi!!
By fan woks you mean inside unit right? assuming so, check remote control settings and battery, set temp.to 70 degrees, a light should come on at the display and seconds later, the compressor should kick in. If Unit is brand new, it should be it. If split units, try another remote, some times those remotes show the display but do not send signal strong enough that the unit can receive it. Try getting closer to the unit.
Keep me posted! Rate this post!!
Aug 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Temp setting way off kenmore 580
Remove the window unit and dissasemble,and clean it out,careful not to bend the fins on the condense and evaporator,but clean them out,and the inside of the unit also,then see what happens,if the problem persist,then find the probe on the evaporator and move it away from the evaporator until the compressor stays on longer.
May 27, 2010 | Kenmore Single Room Air Conditioner
Room temp stays at 76 and will not get any colder even though unit seems to operate and compressor sounds like it turns on and fan blows and water drains . it is set to 60. room is about 300 sq ft
From what you are describing the unit is working perfectly...You just have alot of heat infiltration and the best that unit can do is 76....
If you want or need it cooler you will need to buy a larger size unit...
heatman101
May 06, 2010 | Maytag M6P09S2ACOM Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Fan will not start
Some things you could check first would be to make sure you got all the packing out of it. May just be something blocking the fan blades. Make sure you have the right power supplied to it. Probably 110v 60 cy with a ground which is the normal house plug in the USA. If that's not the problem, I would call the place you bought it from and tell them what's going on with it. If you don't get help there, call the manufacture. In most cases they will have you return the unit for a new one.
Aug 22, 2007 | Fedders V Chassis A6V10S2A Air Conditioner
LG LB8000ER Air Conditioner Logo
236 people viewed this question
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
