Question about Dell 1815dn All-In-One Laser Printer
Scan questions to PC so child can answer
I have Dell E510 with printer,scaner, and fax.window xps
what I need is to put homework on PC so my 5th grader can use it instead of writing (disabled). teacher gives list of questions on single sheets of papers, so I could get those sheets on PC, then my son could type answer and print for teacher.
Thanks
Ken
  • 1 more comment
  • spell202 Jan 25, 2009
    I installed "scan to Office" from ABBYY
    very close to solving problem.
    I move problems to work, but when child starts to type, the answers move. and also text can be moved also.
    someone told me I need it sent as template so only answers could be type in.
    Thanks for all help
    Ken
    got the picture thru Wizard but can,t type answers to questions.
    Thanks
    Ken
  • spell202 Jan 26, 2009
    tried the download, became too difficult
    Thanks
    I need to scan questions to PC, then have the child type in answers.
    Ken
  • Dell Master
  • 19,396 Answers
Instead of scanning original form, that is more complicate, you can design a new empty template form on Office, using Infopath, Word, Publisher, Excel , or Powerpoint.
See below:
Business Forms Tutorials and Templates
Design a view that is optimized for printing
Microsoft Word: Creating a template for a form
Forms and templates - Publications Office
Word e-learning forms
Print Office Forms » Free powerpoint design template
Posted on Jan 26, 2009
  • 10,515 Answers
 You will need (OCR) software. What this does is convert the scanned document into text that can be imported into a word processor.......
The link for OCR is :)
http://www.irislink.com/c2-161-225/Readiris-Pro-11-Demo-tutorial---Fast---Easy-.aspx?adwp=GGS-RI&gclid=CIS20vqlqpgCFZEtpAodzXWKng
I hope i have solved ur querry, do select this post as fixya and take care.
Posted on Jan 25, 2009
  • 63 Answers
You could try scanning it into MS Word as a picture then setting it into the background then you have 2 layers so u can type over the scanned in questions without deleting/moving anything.
Let me know... Matt
    Sergeant:
    Champion:
  • 435 Answers
Hi, the easiest way to do is: Scan the question papers as pictures.
Insert the pictures into Microsoft Word document.
Create template fields at the places where the answer has to be entered. You son can fill it up and print the document.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to Fixya,
Two ways to do this:
  • email - the short way, teacher just emails the questions, your son replies the email with his answers and mail it back (easiest);
  • if questions are already printed/hard copy - run your scanner, scan " list of questions on single sheets of paper" and save the scan image as a *.jpg file, open your OCR program, open/load, process then convert the *.jpg (image file) to actual characters and copy/paste to Notepad or MS Word. This applies to your current concern but would involve your assistance, several steps and honestly, the OCR will not be 100% accurate in copying/converting the scanned image into characters.
Perhaps you can suggest the email method to your son's teacher the next time around.
Pls postback updates. Good luck and thank you for using FixYa
  • 916 Answers
You will need a program to be able to do this you can find the program you need here: Click Here
Just download and install then scan the document in and open it with that program.
  • 362 Answers
Hi spell202,
From the START menu go to all programs, then to Accesories, then to Scanner and Camera Wizard.
Let me know if this helps..Lone99star
  • 44 Answers
Hi1
I think that what you need is to scan some text pages so you computer can recognize the text and modify them in a processor like microsoft word.
Am I right?
If so then I recomend a software named Abby Fine Reader
You can find and buy here.
www.abbyy.com
Thanks for using FixYa
  • BOZAPE
    BOZAPE Jan 25, 2009
    Hi!
    Ok I think that what you need in that case is a way to made a form so your child can only fill the fields.
    In that case I think your best solution is to use Adobe Acrobat. No Acrobat Reader
    With Adobe Acrobat you can create forms so your child can only modify the fields.
    Thanks!
    Let me know
  • 565 Answers
Only possibility is use in scaning the ocr techology then it recomends the text in document and u can save it as word file where your child can type the answers.
most scanners have this possobilty (OCR) but some not.
  • Teet Bergmann Jan 25, 2009
    why do download the proram if scanner dont knows what to do if the scanner dont have the ocr.
    also most scannersoftwares what are gived with cd from manufacturer have the program u recomend already in if they use ocr its comment do u - machadojr_fe
    Genius:
  • 1,847 Answers
Yes you can type the Question on the a Notepad and take the printout of the same ....
  • Legin Varghese
    Legin Varghese Jan 25, 2009
    If you have MS Word software installed on your computer you can use that one. once done with the question and answer, click file on the top and click print.
    let me know if you need further assistance. kevin
  • Legin Varghese
    if you want to scan the question paper and make document of that then you need a OCR program for that. there are many restriction for the working of these program.
    Check this one..
    http://www.irislink.com/c2-865-189/OCR-s...
Dell Studio XPS 435 Desktop Ethernet Driver Windows XP
frank it's many freeware driverprogram on the web.just pick one and scan your computer for updates it will tell you what you need.
Apr 10, 2013 | Dell Studio XPS 435 MT 266GHz 750GB 24 LCD...
Hello,i have this type of printer :samsung scx-4623f.the question is if i can scan without toner cartridge?the toner is empty and i want to use only the scaner,is possible?
Hi there!
It should work, most multifunction works even with no toner in it, just make sure that the scan function and scan driver is installed. You can scan using (for windows XP) Scanners & Camera Wizard. Start>All Programs>Accessories>Scanners & Camera WIzard. for windows VISTA & 7 Click on Start type in WIAACMGR on the start search box and click on it. You can also use Windows fax & scan for windows 7
.Hope this helps. Please rate if this works Thanks!
Mar 30, 2011 | Samsung SCX4623F Laser All-in-One Printer
Cannot get my Canon MX700 to Scan. Also did not get a Guide.
You need to install scaning software that came with the printer to scan and save the file to your PC,Out going faxes should not be an issue if you can copy.Once you install the software tell the program where you want it to save the file in ex: My Documents.During set up you can do this (you can change anytime as well as dpi resolution).Windows has built in scaner set up. Go to start, control Panel, Cameras,scaners.Good Luck.
Sep 19, 2009 | Canon MX700 Office All-In-One InkJet...
My Dell XPS M1530 is locked up. It launches ok but the keyboard and touchpad do not work. I rebooted a few times and it didn't work
thsi guy is **** he put this info on my question too, he only got master rank by putting the same solution on 101 different laptop questions and the websites are all the same. sorry its not an answer but he is annoying
Jul 17, 2009 | Dell XPS M1530 Notebook
Dell 962 printer power and function buttons not working
Hope you can find answers in the manual.
http://support.dell.com/support/edocs/systems/962/en/OM/962_English.pdf
Apr 06, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell Photo 926 printer scanning problems
Go to control panel, scaners and cameras and use that to start the scan
Oct 30, 2008 | Dell 962 Photo All-In-One InkJet Printer
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Scaner computer comunication
These are the steps for Windows operating system.
First make sure you have installed the printer driver software installed sucessfully untill it shows fax setup wizard and complets the entire procedure.
All you need to check is first open solution Center> Go to Settings> And Email Settings> Checked which is the default email selected there if you have outlook select it (But your outlook has to be configure to send Emails fom youe PC) then click on apply and close.
Then in solution center click on scan picture or Scan Document the in the next window where you see (Where do you want to send the scanned images) Click on the drop down and select EMAIL after it has scanned and you click on accept it should open the outlook window on its own where you can put the recepients name and send.
But if in case your outlook is not configured then try the bellow link to configure outlook:
http://www.hostmysite.com/support/email/outlook/
You can also send email from the printer but to enter email address you will need the computer to manully enter email address after it opens outlook window
Good Luck let me know if any problem
Let me know if any problem.
Good Luck
Oct 01, 2008 | HP Officejet 6310 All-In-One InkJet...
Dell 1815dn All-In-One Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
