Question about RCA Scenium D40W20 40" Rear Projection HDTV
The Red,Blue,Green do not line up and keeps blowing fuse
I have a RCA rear projection big screen Model # R52WH74 I replaced a fuse that was blown and It worked for about a day and then blew again. What could cause this fuse to keep blowing
  • RCA Master
  • 8,617 Answers
You need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Posted on Feb 04, 2009
My RCA big screen picture messed up after one of my children fell nto screen?? How can I fix this
The picture on my 52 inch RCA Projection television has green, red and blue squiggly lines around the objects on the screen and the picture looks 3-D.
Oct 30, 2009 | RCA P52960 52" Rear Projection Television
Double picture, red,blue,green lines
consult the Article in the tips and tricks section "the fl231 problem"....it give complete instructions on this simple repair and where to locate the fuse
May 10, 2009 | RCA R52WH73 Projection Television
Red blue green bowed looks like 3d no converg. menu.........
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 09, 2009 | Panasonic PT-51HX42 51" Rear Projection...
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Red green and blue lines on screen
It is common for the 24V supply to fail when the convergence ICs fail. There should be fuses somewhere in the area that should be checked. I don't have the manual for this model, but verify that all of the wires and connectors are attached.
Keep us posted,
Dan
Mar 25, 2009 | RCA P52960 52" Rear Projection Television
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52' rca rear projection model #r52wh74
If i am right you have losted convergence go to menu go to setup look and see if menu has convergence on it if not then you have a open fuse next to FBT on Deflection board located FL231 there are 3 of them it will be the one in the middle.they are small square like caps brown
Oct 08, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH74 Convergence Problem
Yes i replace that fluse fl231 all the time at the shop. at least two aweek. and the first few i replaced did the same thing. I would send it back to customer and i would get a call that the set had malfuctioned again and convergence gone. It was determined the reason this fuse blows is bad conections on the flyback transformer. The flyback is the big black component with the red wire coming out of the top. if you examine the connections on this component there will more than likely be a ring in the solder. this is caused by the manufacturing process known as LEAD-free solder. THis cause oscillations in that cuicit. like turning it of and on really fast. this is a very small fuse and cant stand up to this. so when you replace this fuse just simply RESolder these connections apply a little amount of solder to these connection. i am confident this will fix your problem.
Sep 10, 2008 | RCA R52WH73 Projection Television
RCA Scenium D40W20 40" Rear Projection HDTV Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
