Question about Kenmore 65924 Electric Dryer
Show diagram of belt for kenmore dryer model 66512690
jsrock516
  • 5911 Answers
SOURCE: Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Posted on Jul 23, 2008
woodchuck789
  • 4059 Answers
SOURCE: need diagram for belt and idler on dryer
That model number is not correct. Look here for where it's located. http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Aug 08, 2009
  • 108 Answers
SOURCE: Need help replacing the belt on a dryer.
The tensioner wheel needs to push on the back (the flat side) of the belt. It is a bit difficult to describe, but the way I do it is to loop the belt around the drum and motor pulley only (it will be very loose, but do it as though it wouldn't need the tensioner) then pull back the tensioner pulley and seat it to the back of the belt, so that when you release it, it removes all the slack.
Sorry I don't have a diagram I can direct you to. It is a bit confusing at first, but once you get it, you will be amazed at how simple it is.
Posted on Sep 14, 2009
  • 142 Answers
SOURCE: Kenmore dryer model 110.62066102 electrical wiring diagram
contact manufacture.
hunter19_46m
  • 7482 Answers
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Posted on Nov 16, 2009
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
I have a Kenmore 66512690 dryer , when i press the start button, I just get a buzz like it wants to go but it does not. Could this be the motor?
Based on the limited details the motor is either humming instead of starting and running or the motor is running but the drum is not turning.
This symptom could indicate:
  • Broken belt if it's blowing air out the exhaust.
  • Faulty motor
  • Jammed drum
  • Loose wiring connection
  • Object or piece of clothing article jamming the blower wheel.
Open the dryer door and see if you can rotate the drum in a counterclockwise (CCW) direction. If it's very difficult to rotate then it could have something to do with the motor or drum glide. If the drum will not turn then something is likely jamming the blower wheel.
Jan 08, 2011 | Kenmore Dryers
My Kenmore 66512690 dryer will not heat up or dry cloths. The drom rotates and the motor seems fine.
check your fuses in your panel. If one is gone the dryer won,t run if the other is gone it just won't heat
Oct 27, 2010 | Dryers
Where do i find belt routing diagrams?
Go to repairclinic.com and click on the "Repair Help" link. On the following page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. Depending on the model Kenmore you have, you will refer to either diagram H, B, or K. If you have trouble being able to determine which diagram you should use, please post back with your complete MODEL NUMBER so I can assist you further. I hope you find this information helpful.
Apr 21, 2010 | Kenmore 62602 Electric Dryer
How do I access the belt on my Kenmore model
You have to get behind the dryer and remove the back. This will give you access to basically everything.
Nov 14, 2009 | Kenmore Dryers
Need diagram for belt and idler on dryer
Aug 08, 2009 | Kenmore Dryers
Kenmore 66512690 problem
Appliances which use heating elements almost always have an internal overload protection switch. This overload usually looks like a small diode or resistor somewhere on your incomming power inside the machine. Try to find this overload and bridge it out and try the machine again. These overloads usually have a rather limited life span and are most often the cause of a "dead" machine.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore 65924 Electric Dryer
Removing engine
I need to get the back off of my LG gas dryer. I need to convert it to LP. I have the conversion kit, but can't get the back off the dryer.
Nov 05, 2008 | Kenmore 65924 Electric Dryer
Jul 23, 2008 | Kenmore 62872 Electric Dryer
Kenmore 65924 Electric Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
