Question about Microwave Ovens
Kenmore Elite 363.63692301 inside light not working
  • amartinez1 Apr 18, 2009
    Light inside the microwave no longer works. How do I replace?
How do i replace my microwave with one that has same dimensions?
you shop and shop and shop till you find one that is real close .
Nov 18, 2015 | Kenmore Microwave Ovens
My Kenmore elite built in microwave oven model 790 488 03100 has stoppped heating what can i do
It may be a bad fuse or capicitor. I have had a time in the past with something similar. I contacted Repair Clinic.com. They were very helpful with their advice and even followed up to make sure I got things fixed okay.
Dec 09, 2014 | Kenmore Microwave Ovens
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
Kenmore elite microwave model 665.61682101
This indicates a microprocessor ic control board problem, professional services recommended.
Mar 12, 2012 | Microwave Ovens
Kenmore elite countertop microwave/convection oven
Time for a new cover plate or a new microwave. Depending on the age of the unit, the part may not be available anymore.
Jul 06, 2017 | Kenmore Microwave Ovens
Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
KENMORE ELITE MICROWAVE
F3H is a humidity sensor error.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If it still fails, you have a bad sensor.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 01, 2008 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
108 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
