Question about HP OfficeJet d145 InkJet Printer
HP D145 won't print or anything
We are full on ink and it says supply expired. I have the black ink from hp and the color from another company and it fit just fine. What do I do.
Only hp psc cd 1310 wont work printer copy with on computer but i try look for find it system nothing there printer
Posted on Jan 25, 2009
  • mandeafdunca Jan 25, 2009
    no not they jl 1315 only hp psc 1310
Microboard pf3 is not printing with NEW EXPIRED ink cart.(v101c black and v102c color). please how can i make it work
I had a HP that wouldn't print because the Cart. were past a certain date. I finally just went in to the pc and set the date back, and the Cart. worked fine.
Jun 02, 2014 | Office Equipment & Supplies
My HP Photosmart C6180 All-In-One printer wont let me print using the just the black ink. I have the other colors in the printer but they are expired. I need to print some sheet music and it wont let me....
Inkjet printers require both ink cartridges to be full and not expired before the printer will fully initialize. Even if you are only printing black in both carts do not complete the power up sequence the printer will never go online to print.
Oct 05, 2013 | HP PhotoSmart Office Equipment & Supplies
Hp 610
expired cartidges are not the problem. the problem comes form the ink. get a peice of tissue, place ink on tissue then remove. If black you should see a black line on tissue. same for color, there should be 3 lines on paper, Y,Cy(blue), MGT (Red)
Sep 05, 2012 | HP 610 Color Copier
I have an HP Officejet Pro L7590 All-in-One Printer (CB821A). For some reason it is no longer printing blue ink. I have put a new cartridge in and the digital indicator on the unit itself says it's full....
Hi David! I had HP Deskjet printer at my essay writers for hire company, but color cartridge failed after printed five color photos. So, you are happy man, because you have all colors without blue. It's not so bad.
Jun 07, 2017 | Office Equipment & Supplies
How to use ink I have purchased?
i don't know what printer do you have, but HP print cartridges are resetable, just find it on google, type your printer type and reset cartridge
Jul 10, 2009 | HP Office Equipment & Supplies
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Printer Designjet 110 Plus not working
Ink supplies Description HP part number 11 Black Printhead C4810A 11 Cyan Printhead C4811A 11 Magenta Printhead C4812A 11 Yellow Printhead C4813A 10 Black Ink Cartridge C4844A 82 Cyan Ink Cartridge C4911A 82 Magenta Ink Cartridge C4912A 82 Yellow Ink Cartridge C4913A
alot of printers now if the ink in the cartidge is the first ones placed in the system from the box are those that are only half full if not less depending on the maker but I know HP only fills their cartidges only just under the half way make but the printer sees it as a new cartrige because of the chips programming.
Have you tryed to turn the power of and let is sit for about 5 mins and turn it back on with the same result? (ushally a yellow error light is on)
Also if you can find the settings to only print in black and white on the printers properties that might also work as well for a temp fix.
But ushally once one ink runs out it likes to do that you where correct with the "is it because of the finished color cartidges.." either that or the carts all have finally expired.
Nice printer by the way.
But your best way to do it would be to replace the color carts and if not reasonable to do now there is also a way to reset the color carts so that the printer thinks that there is ink in them as well.
hope this helps you a bit if you need more info please let us know.
Aug 02, 2008 | HP Designjet 110plus nr InkJet Printer
Hp printer 7110
hi,
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
7110 supply expired
According to posts on a another forum, you can fix this problem by unplugging the printer, removing the battery or sticking a business card between the battery and its contact point. It should work when you plug it back in.
Jun 15, 2008 | HP OfficeJet 7110 All-In-One Thermal...
HP OfficeJet d145 InkJet Printer Logo
153 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
