Question about Tablets & eReaders
Update firmware proscan plt8031 - Tablets & eReaders
Firmware for proscan plt7100g
The only firmware for the PLT7100G is available here: http://www.proscanvideo.com/item.asp?itemnmbr=PLT7100G . The direct link to the firmware is http://www.curtisint.com/html/custservice/manuals/PRO_PLT7100G_FIRMWARE.ZIP .
Unfortunately, this firmware update may not help with the app problem that you are having.
Jun 02, 2016 | Tablets & eReaders
Will not power up. I Have tried the reset and it still will not help how do i get on it
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2015 | Tablets & eReaders
My avoca tablet is stuck on avoca loading screen
I have downloaded the firmware and updated my proscan plt8235g tablet but it still stuck on boot screen.
Sep 01, 2014 | Tablets & eReaders
My proscan tablet keeps crashing. It says google play has stoping working. I've reset the tablet twice. what can I do?
Keeps crashing because can't handle too many tasks at one time. I have the same problem. I have the same problem. Try the pin hole reset next to the HDMI input . Press in gently with a paper clip and hold for thirty seconds.
Google play? Try uninstalling updates. Disconnect from internet when not in use.
These tablets have lots of problems not easily solved because there are no firmware updates for this model.
May 25, 2014 | Proscan 10.1-Inch Internet Tablet,...
Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Apr 02, 2014 | Proscan 8 4GB Android 4.1 Tablet
Proscan 8 inch tablet with android 4.1 jelly bean
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
I am stuck on the boot up screen and wont let me reset
Pull battery. or
search for cmd.com
execute cmd.com
type in " shutdown /s " to shutdown the computer at command prompt
type in " shutdown /r " to reboot the computer at command prompt
Jan 21, 2014 | Proscan Recertified - PLT8031 4GB NAND...
How to unlock tablet proscan PLT7223G
Download the firmware update PRO_PLT7223G_FIRMWARE.ZIP
Download the RockusbDrivers from https://docs.google.com/file/d/0B_keThrKc71iYkZXMHNxZWdVT0U/edit
Save these files to a new folder on your desktop.
Unzip the FIRMWARE file and follow the instructions. When you need the tablet drivers, manually install the drivers from the RockUSBDrivers files in the new folder you created.
Jul 19, 2013 | Tablets & eReaders
I forgot my pass word to my proscan plt8031 tablet
This is everything you need to know to root/unlock/factory reset your Proscan 8" Tablet a.k.a. PLT8031.
First thing you will need to do is charge up your device, download the software needed to your desktop or some other easily accessable folder. Now this is the part that took nearly 3 days to figure out in order for the program to recognize and load an image to it you have to put the device in "recovery mode". You might ask well how do I do this, as every forum out there just says put in recovery mode and it will work, BUT HOW you still ask. The internet won\'t tell you, the company won\'t tell you, hell even other people on forums won\'t tell you. But alas I shall.
RECOVERY MODE Proscan PLT8031
Simply plug in your usb cable to your computer, then while holding your menu button, to clairify as I don\'t know the exact name of the button, it\'s the one to the left of the home button. plug in the usb cord to the device while still holding that button. Do not let go of the button until you see that windows has detected your hardware and is looking for a driver.
FYI windows usually will not find a driver, I have included links to the drivers you will need.Now if your at all used to device manager you should know how to point it to the driver you need. It will be called "rockusb.inf".
Once this is installed then open and run "RKBatchToolv1.4" as administrator. You then need to click the three dots in the top right to locate and load the "update.img" file. Make sure at this point that your device is recognized with a "green square" near the bottom of the window.
If all that checks out click the upgrade/restore button. To be clear it\'s one or the other, not both, technically didn\'t see a difference between them. This process will then start and will take between 5 to 10 minutes. DO NOT TOUCH ANYTHING. if you unplug your device too soon you will have a nice paper weight instead of a tablet. Wait untill it is completely booted into the setup your android device screen before closing the rkbatchtool and safely disconnecting the device.
Congrats on your newly rooted/recovered plt8031 tablet.
29RockUSB Driver - http://uploading.com/2ca29934/29Rockusb-zip
http://www.generalfiles.com/download/gs5a611f4bhci0/29Rockusb.zip.html
http://rapidlibrary.com/files/29rockusb-zip_ulcqxffyzwieon.html
If none of these work for you just google "29RockUSB" without quotes.
Firmware (update.img) - http://www.proscanvideo.com/tech-help/PLT8031.asp
RKBatchToolv1.4 - http://www.filecrop.com/RKBatchTool-1.4.rar.html
http://www.x-drivers.com/catalog/flash/tablets/companies/fuzhou_rockchips_electronics/models/rk_batch_tool/27575.html
Dec 06, 2012 | Tablets & eReaders
Tablets & eReaders Logo
123 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
