Question about Kenmore Refrigerators
I have a Kenmore Coldspot, model 106.55642500, the refridgerator section is not cooling sufficiently.
I cleaned the coils but it still is not cooling properly, the freezer section is fine.
sdmc73
  • 121 Answers
SOURCE: fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Posted on Nov 29, 2008
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
lojacksdad
  • 121 Answers
SOURCE: I have a Kenmore Coldspot 106.53504300 The
you need to check if the compresser is red hot if so change the relay to a 3 and 1 overload relay very easy to in stall
trick put a floor fan pointed at the compresser let it run a while see if you notice a difference
Posted on Apr 17, 2009
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Hi my refridgerator is not cooling and the fridger section is also not working, every thing is been melted. we can here the refridgerator running but its not cooling.
b44df16.jpgIs the fan motor running below and the coils clean? 8dff5ce.jpg6e3f9f7.jpgIf nothing is running but the light is on you might have a stuck defrost timerb365bb7.jpg
Aug 30, 2010 | Kenmore Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Refridgerator will not run
if it have a thermostat it can be your problem
Jun 16, 2009 | Kenmore 64802 Top Freezer Refrigerator
Apr 17, 2009 | Refrigerators
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge side not cooling
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot
Behind you crisper drawers is an opening to the freezer compartment for air return from the refrigerator. If it is blocked it can cause the problem you posted. The temperature of the refrigerator section controls the running of the system.
Jun 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
