Question about GE Spectra JBP78 Electric Kitchen Range
Replacing baking element for GE Truetemp
I have a GE TrueTemp electric range (model J BPOWOB1WW) whose baking element has gone out (burned out and broke apart). I ordered the part today, thinking I could replace it myself, but taking a look at the connection, I'm not sure I can.
Will I be disconnecting the ends of the element from the wires while reaching inside the oven--that is, unscrewing the plate and pulling the element toward me to reach the connections; or taking off the plate on the back of the oven, disconnecting things from there, and pushing the ends of the new element through the insulated slot, and reconnecting the wires to the element from in back?
Either way, the way the element ends are connected to the wires puzzles me--no obvious, easy parts to pull apart or unclip and reconnect, no simple unplug and replug. But then I don't have the part yet and don't what the end of it looks like. Do I need to rewire?
I'm not a fix-it kind of guy, but I'm trying to improve myself.
Thanks,
John
  • 1 more comment
  • jmulvi49 Jan 25, 2009
    I don't see the on/off connection. I've taken a photo of the connection, and tried to use the "Insert Image" function, but apparently the file is too large. May I send it directly to you?
    John
  • jmulvi49 Feb 08, 2009
    We got it figured out once we got the part. The problem was that the leads were stuck and impossible to unplug without some persuasive WD40. Thanks for the help.
  • katehoesly Mar 02, 2009
    i have the same problem, where'd you get your new element at??
I just had the same problem. Just remove the rear panel of the range and unplug the two leads. Now go to the two screws inside the oven and remove them. The heating element will now come out and you can insert the new element the same way. Replace the two screws inside the oven and then attatch the two leads in the rear. Replace the rear panel and you are set to go.
Posted on Feb 08, 2009
    President:
  • GE Master
  • 2,651 Answers
They are easy on/off connections. either down from inside or the back, no difference. DISCONNECT POWER FIRST ALWAYS LIVE< this is a do-it-yourself issue. youll be fine
Posted on Jan 25, 2009
  • Ron Coons
    Ron Coons Jan 25, 2009
    dont really know ifthe website allows selfpromotin of personal websites, so id rather you tried to repost a cmaller image, but in twenty years i cant really pictire any bakle elemnt that is either no t a simple push in terminal,or i guess its possible that teh new elemnt comes with a screw to resecure the wire, lets wait till the new elemnt arrives and have a look at it, before we try to delve further into an issue that may not be an issue afterall!
When the oven is on, there is a constant buzzing noise until the oven cools off. it is not the convection fan!
I would call a repairman to check for a loose wire . buzzing could possibly start a fire eventually
May 23, 2016 | GE Profile PS905DPBB 30" Slide-in Electric...
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
It is beeping with F7 displayed
Hello. The error code is telling you that you have a defective key panel(control panel). The part number you need is WB36T10668. The main oven control board is WB27T10416. I hope I helped you!
Jul 29, 2015 | GE JSP42DNWW 30" Slide-in...
My probe beeps when I use my oven, how do I correct this
I'd reset (Turn off and back on) the Oven circuit breaker to see if that fixes. Otherwise, Owner's manual troubleshooting.
No manual? try this: http://www.manualslib.com/
Mar 09, 2015 | General Electric Profile PD900DPBB 30"...
JKP70-27" SINGLE CONVECTION WALLOVEN
Replace the transformer and hope nothing else went bad. Good luck!
May 27, 2014 | GE JKP70 27" Single Electric Wall Oven...
I have a GE TrueTemp oven/range - oven is not working
I had a similar problem.The power failure might just have been a coincidence.Sounds to me like your lower oven igniter may have gone bad such as mine did.
Jul 14, 2010 | GE JGBP33 Gas Kitchen Range
Help.
Unplug the range.
Remove the oven racks.
Remove 2 screws holding the element to the back wall.
Slide the element towards you carefully. Remove the wires and install them on the new element.
Reattach the element to the back wall.
Mar 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
1,268 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
